  • 8.2.0.1 scheduled for upload. I will update the changelog later today. Please update your device trees with this release as it would allow the new feature - automatic device tree update - to work for the future builds.
    But, ksaq, says there are new device trees, I think I'll wait
    Synology DS414 Plex Pass
  • All 8.2 device trees have been updated with "le-dt-id" field to allow to identify them for the device tree auto-update feature. You can safely use an "old" 8.1.x device tree with 8.2.0.1 build.
  • 8.2.0.1 (small) changelog is now in OP.
    About automatic device tree update:
    When upgrading to 8.2.0.1 or later you no longer have to provide a device tree for an update, it will be updated automatically. The only condition is that you have to be using a device tree from 2017-10-28 or later. You can check it by running this command: cat /proc/device-tree/le-dt-id. If this command gives you device tree name, you have all that is needed for an automatic update.
  • Working very well here, thanks again for the great work! 8)
    Minix Neo U1, S905 chipset, 2GB/16GB, Dual Boot Libreelec / Android 5.1 lollipop, Samsung UHS-1 32GB Micro SDHC Memory card
  • I'm sorry I'm new here. The first page of this thread doesn't have any tutorials on how to install LibreELEC to the internal memory, how do I install it to my internal memory ?
  • with the sd card plugged in, ssh in, installtointernal some devices you need to do it twice.
  • DVBViewer Buffing on Kodi 17.5
    Dear @kzsaq, have you resolved this issue and would you be able to integrate this into your software as much as possible?
    No, I have not. afl1 has some improvements but they are not public yet.
  • kszaq On a reboot or power on , I sometimes or most of the time i get an error no free adapter available when i try to play a tv channel for my usb tuner. It has been doing this for a while and not due to this update.
    Simply unplugging the tuner from usb and plugging it back in solves it.
    Not sure why. Error from dmesg
    TX7 See Signature.
    dvb-usb: Sony PlayTV error while loading driver (-12)
    ############################################## # LibreELEC - Pastebin.com
  • i have an mxq pro booting libreelec from internal
    does libreelec write the dtb to the dtb partition or is it just stored on the system partition?
    e.g. how do i update to todays dtb
    i think i used gxbb p200 1gb mxq pro 4k.dtb
    should i use gxbb p201 1gb.dtb?
    ro.product.model=MXQ Pro
    ro.product.brand=Android
    ro.product.name=p201
    ro.product.device=p201
    ro.product.board=p201
    PCB
    MXQ-S905-D16
    Ver:1.0 Date:151021
    WIFI RTL 8189ETV
    NAND 8GiB SK hynix H27UCG8T2ETR BC
    RAM SAMSUNG K4B461646B-HCK0
    Edited 4 times, last by Shonk ().
