Nope, as far as I can see I have only inputstream.adaptive v1.0.8.
No other inputstream addons present.
weird, I see it here: rb-addons/addons/8.1/Odroid_C2/arm/inputstream.rtmp at master · Raybuntu/rb-addons · GitHub
Well yeah, he has it there, but I haven't installed it. Inputsteam.adaptive is the successor of inputstream.rtmp as far as I know.
Here's the log, where you can see which add-ons are installed: eOYE There is no inputstream.rtmp mentioned.
I tested on my RPi: the librespot works fine without any inpustream addon.
So let us try to assess differently.
First determine if the service runs correctly:
Any errors?
Nice approach!
here you are (errors indeed):
LibreELEC:~ # librespot.start
ffmpegx: error while loading shared libraries: libmmal_core.so: cannot open shar ed object file: No such file or directory
INFO:librespot: librespot 3fd667b (2017-07-05). Built on 2017-07-05.
*** WARNING *** The program 'librespot' uses the Apple Bonjour compatibility lay er of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd ns_sd&e=librespot>
INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-xj7b.ap.spotify.co m:4070"
INFO:librespot::session: Authenticated as "*******" !
INFO:librespot::session: Country: "DE"
INFO:librespot::player: Loading track "Two Weeks"
INFO:librespot::player: Track "Two Weeks" loaded
INFO:librespot::util: Running kodi-send --action=RunAddon(service.librespot)
close failed in file object destructor:
sys.excepthook is missing
lost sys.stderr
INFO:librespot::util: Exit status: exit code: 0
thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: Err or { repr: Os { code: 32, message: "Broken pipe" } }', /checkout/src/libcore/res ult.rs:859
note: Run with `RUST_BACKTRACE=1` for a backtrace.
Display More
During this my Android app showed that track is playing on [email protected] But actually it did not.
Then the device ([email protected]) disappeared from the overview of connect devices in android spotify app.
Hope this helps to narrow it down somehow.
Display MoreNice approach!
CodeDisplay MoreLibreELEC:~ # librespot.start ffmpegx: error while loading shared libraries: libmmal_core.so: cannot open shar ed object file: No such file or directory INFO:librespot: librespot 3fd667b (2017-07-05). Built on 2017-07-05. *** WARNING *** The program 'librespot' uses the Apple Bonjour compatibility lay er of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd ns_sd&e=librespot> INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-xj7b.ap.spotify.co m:4070" INFO:librespot::session: Authenticated as "*******" ! INFO:librespot::session: Country: "DE" INFO:librespot::player: Loading track "Two Weeks" INFO:librespot::player: Track "Two Weeks" loaded INFO:librespot::util: Running kodi-send --action=RunAddon(service.librespot) close failed in file object destructor: sys.excepthook is missing lost sys.stderr INFO:librespot::util: Exit status: exit code: 0 thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: Err or { repr: Os { code: 32, message: "Broken pipe" } }', /checkout/src/libcore/res ult.rs:859 note: Run with `RUST_BACKTRACE=1` for a backtrace.
Got it!
ffmpegx for RPi2 is built with mmal support, which is apparently lacking on Odroid_C2/arm. I am sure Raybuntu will build the addon, if you ask him to.
Is this mmal thing something raspberry specific? How does your addon work then on aarch64 systems like the official 64bit C2 builds? Is mmal mandatory for it, also in the future?
Good that we know the issue now
ffmpegx (which streams librespot output to RTP) uses project specific hardware acceleration support, such as mmal. Using ffmpegx built for a project (RPi2/arm) on another project (Odroid_C2/arm) might therefore not work.
I will see if I can add features required by librespot (native PCM transcoding and RTP) to ffmpeg provided by LibreELEC, but that will be for LibreELEC 9.0.
In the meantime, a solution is to build the addon (or ffmpegx) for Odroid_C2/arm.
I will have to refresh my addons repo for LE8. I'm unable to test Spotify. I'm currently focusing on LE9. Are those new features merged at LE already? If it was merged lately I might not had the chance to pull and build it yet.
My Addons are built natively for the platform, so infinity85 should use my rb-leia builds for C2 and install those Addons from my repo. But please report all issue to me.
Mixing RPi addons with C2 will not work in this case cause it's linked against libmmal which is not used by C2 nor necessary to build.
Those new features have been merged into LE 8.0, 8.2 and 9.0.
Thanks I just saw in git log. But it was just merged 2 days ago and I didn't pull yet. Will be updated soon.
Revision 102 of the addon fixes the issue. Please update.
Since GDPR-1 released a new LE build, the kodi-output option finally started working
Now I see what the aim was, to include this function:
However there are some issues I'd like to mention and to get explained, if possible:
librespot.start
INFO:librespot: librespot ebeb776 (2017-07-08). Built on 2017-07-08.
*** WARNING *** The program 'librespot' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=librespot>
INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-f822.ap.spotify.com:4070"
INFO:librespot::player: Loading track "C O O L"
INFO:librespot::player: Track "C O O L" loaded
=== args='time_base=1/44100:sample_rate=44100:sample_fmt=s16:channel_layout=0x3'
=== args='sample_fmts=s16:'
[rtp @ 0x1644f30] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: WireError("invalid value for enum: 12")', /checkout/src/libcore/result.rs:859
Display More
And a second attempt:
INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-dz71.ap.spotify.com:4070"
INFO:librespot::session: Authenticated as "wmissal" !
Two different issues here, apparently. And after that it dissappears again as available device in the smartphone app. Need to restart Kodi.
Independently from the other issues: Once the connection works the song starts playing after ca. 5s on Kodi and plays for about 3s. Then the sound disappears, the timestamps seem to jump betweet 4 and 5 seconds up and down (like a hickup without audio)... this takes about 5 seconds and then the song proceeds to play. Observed this many times.
Thats the log for this:
13:38:25.155 T:4100526080 NOTICE: VideoPlayer: Opening: special://profile/addon_data/service.librespot/librespot.sdp
13:38:25.155 T:4100526080 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:38:25.159 T:3459371936 NOTICE: Creating InputStream
13:38:25.163 T:3459371936 NOTICE: Creating Demuxer
13:38:26.257 T:3459371936 NOTICE: Opening stream: 0 source: 256
13:38:26.257 T:3459371936 NOTICE: Finding audio codec for: 65542
13:38:26.257 T:3459371936 NOTICE: Creating audio thread
13:38:26.258 T:3642401696 NOTICE: running thread: CVideoPlayerAudio::Process()
13:38:26.268 T:3642401696 NOTICE: Creating audio stream (codec id: 65542, channels: 2, sample rate: 44100, no pass-through)
13:38:26.277 T:3459371936 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
13:38:30.085 T:3642401696 NOTICE: CVideoPlayerAudio::Process - stream stalled
Display More
"stream stalled"
In kodi the showed playtime does not display the correct values. It is simply proceeding and doesn't start counting from 0 after the next song starts playing. It is always showing proceeding times like this: 06:48/06:56 with a delta of 8s between both times.
That's a load of issues, so I guess it is platform specific here, isn't it?
Display MoreSince GDPR-1 released a new LE build, the kodi-output option finally started working
- Ability to control Spotify through KODI Interface
- This was unclear for me and that's why I asked twice why you included this function (didn't know your itention)
- (Using KODI output instead of ALSA:) After choosing [email protected] in my Android Spotify app the connection seems to have trouble getting established. It is mostly done successfully after the second attempt.
- The librespot service seems to crash after one track and [email protected] device disappears as an available spotify device in Smartphone App. I need to do librespot.start to get it appear again. Here's the log then:
CodeDisplay Morelibrespot.start INFO:librespot: librespot ebeb776 (2017-07-08). Built on 2017-07-08. *** WARNING *** The program 'librespot' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=librespot> INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-f822.ap.spotify.com:4070" INFO:librespot::session: Authenticated as "*******" ! INFO:librespot::session: Country: "DE" INFO:librespot::player: Loading track "C O O L" INFO:librespot::player: Track "C O O L" loaded INFO:librespot::util: Running kodi-send --action=RunAddon(service.librespot) INFO:librespot::util: Exit status: exit code: 0 === args='time_base=1/44100:sample_rate=44100:sample_fmt=s16:channel_layout=0x3' === args='sample_fmts=s16:' [rtp @ 0x1644f30] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: WireError("invalid value for enum: 12")', /checkout/src/libcore/result.rs:859 note: Run with `RUST_BACKTRACE=1` for a backtrace.
CodeLibreELEC:~ # librespot.start INFO:librespot: librespot ebeb776 (2017-07-08). Built on 2017-07-08. *** WARNING *** The program 'librespot' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=librespot> INFO:librespot::session: Connecting to AP "gew1-accesspoint-b-dz71.ap.spotify.com:4070" INFO:librespot::session: Authenticated as "wmissal" ! INFO:librespot::session: Country: "DE" thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: WireError("invalid value for enum: 12")', /checkout/src/libcore/result.rs:859 note: Run with `RUST_BACKTRACE=1` for a backtrace.
CodeDisplay More13:38:25.155 T:4100526080 NOTICE: VideoPlayer: Opening: special://profile/addon_data/service.librespot/librespot.sdp 13:38:25.155 T:4100526080 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 13:38:25.159 T:3459371936 NOTICE: Creating InputStream 13:38:25.163 T:3459371936 NOTICE: Creating Demuxer 13:38:26.257 T:3459371936 NOTICE: Opening stream: 0 source: 256 13:38:26.257 T:3459371936 NOTICE: Finding audio codec for: 65542 13:38:26.257 T:3459371936 NOTICE: Creating audio thread 13:38:26.258 T:3642401696 NOTICE: running thread: CVideoPlayerAudio::Process() 13:38:26.268 T:3642401696 NOTICE: Creating audio stream (codec id: 65542, channels: 2, sample rate: 44100, no pass-through) 13:38:26.277 T:3459371936 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED 13:38:30.085 T:3642401696 NOTICE: CVideoPlayerAudio::Process - stream stalled
"stream stalled"
- Similar: In kodi I see how librespot is showing the now playing info: "Librespot 00:xx / 00:xx minutes", but I cannot find it in Music section of Kodi? How do I access the controls/playlist in Kodi then?
- Also playing a continuing playlist does not work apparently. After one song is finished it jumped only once to the next, and after that one playback stopped and crashed apparently (as the [email protected] device disappeard again). Mostly it does not even play the second song.
- Controls through smartphone (play/pause/skip etc.) seems to be without any effect? Perhaps supposed to be this way?
Spotify changed its API and broke librespot yesterday morning, librespot was fixed yesterday evening, and the addon was updated just after that. Raybuntu should update the addon he provides.
As for Librespot through Kodi behaviour:
- Kodi user has priority over Spotify user (Librespot is not active when Kodi user is playing back a media, Kodi user can stop Librespot streaming, etc.)
- Librespot is controled via a Spotify app (start, stop, pause, etc.)
- Librespot streams to Kodi via ffmpegx/RTP, which introduces latency.
Okay, I'm still a bit confused, sorry for that...
What is "spotify user" in your view?
So far I understood:
If my point 2.) is understood corretly by me. Then the unsuccessful control via smartphone app was caused by the changed api, or is this something that is still WIP? It is actually supposed to be controlled through, smartphone app, if issues are resolved, right?
And where do I find in kodi the currently played playlist? Is the playlist not present because the audio is simply streamed to kodi from librespot via via ffmpegx/RTP without further infos (e.g. playlist info and track info) as a pure audio-stream?
Thanks for your patience and the time you took to explain it
Hey I just upgraded really easy from openelec to LibreElec 8.0.2 on Linux
I did this to get Librespot (8.1.102). That add-on works great, very impressive
After a reboot of linux I do see librespot as a running add-on
But my phone doesn't see it..
I go to librespot > configure > ok (left everything as it was)
And now my phone does see librespot
How do I get this to work when I boot into Kodi ?
Edit
Solution here
Hey,
maybe I should note here that even the older 100a version (2 weeks ago?) works with an ODROID C2 (32bit raybuntu krypton13 or 14).
However it doesn't work reliable. Sometimes it does, sometimes not. If not, I restarted the device, which increases the chance of success. But if it works, it works great. Like a car: if it rolls, it rolls
I will test your new version tomorrow to give you newer feedback if needed!
Here is a new preview release that attempts to solve two issues:
- latency in streaming to Kodi
- audio device not ready on service startup ( Camella)
On RPi2 latency is significantly improved
I have no hardware to test that audio device is ready before librespot service starts.
Thank you for you feedback.
Preview for RPi2 (should also run on Odroid_C2/arm)
