Custom update Channel for S905/S905X
  • Just put the url in the custom channel. It will download and restart.
    Thank You.
    LE Settings just saw the option to enable custom channel.
    sorry u meen this ? Index of /s905/device_trees/ ?? this is need only for install for updane no
    If future Update is released and requires device tree Update for that release, what will we have to do ?
    I added the https://qwerin.cz/kodi/s905.php as a Second custom channel without really knowing what this will do.
    Is this correct ? or will there be a prompt to choose the correct device tree when choosing a future update that requires a device tree update ?
  • Works fantastic. Thanks a lot!
    On which device? Does nothing on my x96 (905X 2/16) :huh:
    Tried ALL combinations of Updates Manual / Auto
    Custom Channel update.php / update.php / updateAll.php / updateAll.php
    downgraded to LE 8.0.1e. Reset after reset - nothing
    Edited once, last by Poida ().
  • On which device? Does nothing on my x96 (905X 2/16)
    This is only an option to choose a custom channel (url) in Krypton 8.
    Not Jarvis 7.
    It worked for me on my MiniMx S905 1gb/8gb.
    I updated from 8.0.1g to 8.0.1h.
    It only Updates to latest Version.
    There is no choice to choose an earlier version.
  • kostaman Doesn't work with my MiniMX S905 2/16 boxes either
    I have also tried the s905.php variant but nothing happens at all
    I have downgraded boxes to lower 8.0.1 versions but zippo :s
    Hmm must be missing some setting, somewhere.
  • Hmm must be missing some setting, somewhere.
    DOH! Didn't have the Update Channel set to 8.0 LOL :D
    ONLY works with Manual updating though, right?
  • DOH! Didn't have the Update Channel set to 8.0 LOL
    Just about to send you a screenshot of settings i have.
    Bingo Update Channel LibreELEC .8.0.
    No Idea why LibreELEC . 7.0. is even in there.
    I cannot see this custom Channel setting in the Menu using Jarvis 7
    Downgrading from 8 to 7 would wipe your settings/addons etc.
    No idea about Auto Update.
  • qwerin - Excellent work
    kostaman - Thanks for your help
    wish-list: Please Santa, make this work with auto update :angel:
  • great work, it works really nice, only request i have is that it shows all available versions.
    Like i update my fathers device sometimes only once a month, so when i want to go to last version i need to install now all versions between them.
    Example: i had f installed and first had to install g to be able to install h
  • I have an addon for updating the firmware from your dropbox account. If anyone is interested I'll post it.
    MXQ M10 S805 - LibreELEC 8.1.9
    NEXBOX A5 S905X - LibreELEC 8.1.9
    BEELINK MXIII II S905X - LibreELEC 8.1.10
  • Is the 'Update Notification' setting supposed to work?
    To me it only showed the latest. I was on e, when I checked available versions it only showed h and updated to that directly
  • To me it only showed the latest. I was on e, when I checked available versions it only showed h and updated to that directly
    weird then :) so maybe it was just a bad luck in my case :)
    I guess not then :angel:
  • I guess not then :angel:
    Why did you want that? I Have an addon that you can set a notification to tell your family that there is an update for their box??
