  • What is wrong with the latest build?
    I was just asking a question. I wasnt trying to say anything was wrong. Sorry if it appeared that I was trying to suggest that.
    TV: Vizio 2017 M55-E0
    Streaming Apps: Roku Streaming Stick+ for 4K/HDR Netflix, Youtube, and Amazon Prime Video
    Kodi: Minix Neo U9-H w/LE installed on MicroSD
    Remote: Harmony Elite
    Media Server: Unraid 40TB BEAST!
    TV Tuner: 2x HDHomeRun Prime
    Server Apps: HDHomeRun DVR, Emby (for Kodi), Plex (for everyone else)
  • Would it be possible just to close the thread?
    Synology DS920+ Plex Pass
  • Ok, so no more builds for now except that probable 8.2.3 update.
    Thanks for your work on these builds up to now and thank you for your contribution to the amlogic realm.
  • In current builds resolutions other than 1920x1080 and 4K are not supported on S912 - read the first post, please!
    I am using a 4k TV and minix U9H. When playing files of different resolution (not 4K) the switch will result in a size bigger than the TV default? i.e. a bigger scan area? When I stop playing (not pause), the resolution switches back. Did not notice this in previous builds i.e. 8.2.2.1.
  • Using a 32 gig usb 3.0 on minix u9-h I've notice it won't boot however, when I check the flash drive it's 3 partitions when I've read it should be only 2..do I need to use a microsd or anyone with a u9-h know a workaround to get this to load... Whats strange I have a neo u1 by minix and it loads no issue with a 16 gig flash drive.
    Thx in advanced.
    Can't access tty; job control turned off is the error message
    Edited once, last by Admiral2145: More info ().
  • And turning it back on?
  • A fix for resolution switching on S912 is ready to be included when LE 8.2.3 comes out.
    This means: you will be able to switch to 1280x720. Not a big deal but always something nice to have.
  • Short question: Iam planning on buying a M8S Pro L with S912 but it the beginning of this thread kzaq says:
    Quote
    Amlogic has not released fbdev Mali libraries and has no plans to release them. These builds use libhybris and Android gralloc Mali driver to provide OpenGL for Kodi - an experimental approach with CPU overhead - meaning suboptimal GPU performance.
    If you consider buying a device for LE, do not buy Amlogic S912!
    But in this thread(the box guide): Choosing a S905 / S905X / S905D / S905W / S912 box guide wrxtasy says:
    Quote
    Do NOT buy a AMLogic S912 box for LibreELEC, due to ongoing Linux/LibreELEC GPU video driver issues.
    S912's virtually all fixed with @kszaq's LE 8.1.8 release onwards. Impressive GPU optimisations by kszaq for S912's lately !
    Which of this is true? :)
    This means of course ability to set lower GUI resolution, not to switch to lower output resolution if movie res < GUI res? In other words if I want TV to scale up instead of BOX, I'll still need to keep GUI/system resolution at 720p?
    Btw, is it still better to pick up S905X instead of S912? I know about lack of driver and hack you've used but GUI wise they both seem to work properly and decoding wise they were the same from the beginning, right?
  • Both are opinions from 2 different points of view: mine is from developer, and in this case wrxtasy is a user. I have to admit that at first running LE on S912 was a bit painful experience but I managed to make it run much better and it's fine for a daily driver.
    Yes, Kodi won't switch to lower resolution. You have to keep GUI at 720p. Switching to a lower res is considered to be added in Kodi Leia.
    Yes, the only "hack" in S912 builds vs S905 is GUI rendering. Everything else works natively.
  • i was using a s905x box before, which was great. However the 100Mbit Ethernet was starting to be a bottleneck with the availability of high Bitrate 4k Content.
    So I wanted a box that does 4k, HDR10, has a Gigabit port and libreelec running on it. Afaik the s912 is the only chip that checks all those boxes.
    I am pleasantly surprised how stable it is The OP mentions random reboot, which I haven't experienced any in the 2 weeks I use my box. If 720p resolution switching is added in the next update, everything I want it to do will be possible.
    Huge thx to kszaq
