  • Hi guys, pretty noobie here,
    1.
    I have ordered the H96 PRO PLUS+ BOX from Banggood. I have seen some custom ROM on the website called FREAKTAB which is actually available in two versions one is a customised version know with SCV and the other is the Android TV version.
    2.
    And the bugs that are being fixed is pretty amazing there and there is no need for Dual boot and a lot of fixes like 4K youtube and Passthrough features are enabled and hell of a lot of fixes. So, can you suggest which is the best if any of you have tried and why it is better than Libreelec.
    Perhaps it would be easier, if you tried these versions, then installed Librelec on a sd card to see for yourself.
    Synology DS920+ Plex Pass
  • frequenzy Thanks for the reply. I will definitely use the SD car so I don't stuff anything up.
    button but there is the usual "hole in the side" that looks like it is probably a reset button. I'll give that a try and if no joy I'll try the others.
  • Why wont my whole post come out? It's missing about 5 lines and no matter how I try to type it or edit it only the first line comes out saying I need help.
  • People in our forum have exorcised Android from their devices so won't be much use for detailed comparisons with a specific custom ROM image they are not using. Go experiment and make your own decision.
  • My H96 Pro Plus was auto updated to 8.2.2.2 and 8.2.2.3 from 8.2.2.1a but now auto frame rate wont go lower then 50 Hz. On 8.2.2.1a it would go down to 23.98 and 24 Hz. In Setting/System Display Refresh Rate I also see only 50.00 59.94 and 60.00. What is wrong and is there a fix? Powering everything down and up wirh H96 latest doesn't help. On 8.2.2.1a all refresh rates were shown from 23.98 to 60. Can I get 8.2.2.1a somewhere and install it?
    Dikkie, are you running 8.2.2.3 from internal memory or SD on your H96 Pro Plus?
    After a few days, I'm running into boot issues after installing to internal memory on my H96 Pro Plus.
  • Always use SD card....
    I have no problems running this on my H96 Pro +
    Ok that explains. Running from SD always works on my side too.
    See this post. Probably a slow internal memory / emmc in H96 Pro + is the problem.
    For S905 this is fixed by using an adjusted dtb file.
  • Ok, I have successfully installed LibreELEC onto an SD card and booted it. Yay. However, now the remote wont work so I can do anything. Is this a common problem and is there a fix?
    remote.conf repository
  • How important is the usb/micro SD quality? I've been using like a 5 year old or more 8gb SanDisk Cruz usb and everything seems to be working fine. However I had a gift card so I bought a 32gb SanDisk ultra microSD HC with speeds up to 98MB/s. Just wondering if I even actually need it, what it would improve?
  • Ok, one more question. How do I set the correct time? It seems to have picked up the correct date but not time and I can't find the "set clock" option anywhere.
  • UTC time is set using NTP over the network. Display time is then offset from UTC according to whatever timezone you set in Kodi.
  • Hi, have you managed to fix that? I also have H96 Pro+ (S912) and passthrough doesn't work for me when connected via TV HDMI and then AVR (ARC everywhere). I've tested Chromebox, Wetek Core and ATV 4K and all worked fine with same settings. Is it issue with unofficial build or the box itself?
  • For audio passthrough you have to disable Settings->Player->Videos->Sync playback to display.
    If you enable this option all multichanel audio is decoded to Multichannel PCM. SPDIF is capable only stereo PCM.
