Is 8.2 stable??
kszaq -
March 3, 2017 at 7:18 PM -
delz I will give you some hints so that you can answer this question on your own:
- There is no official LE 8.2, not even a beta from this branch.
- I have not released any 8.2 build for S912 - no time to test and S905 is a better target for first tests.
- danxc Took the untested code and compiled it.
Now you can decide if it's stable.
Is 8.2 stable??
The build had been labelled "testing", S912 has never received an official stable build (read first post) and LE has not even been released yet. Please apply some common sense.
EDIT: Lol, kszaq beat me to responding just a minute earlier with exactly the same thoughts.
Is 8.2 stable??
For me 8.2 is better than 8.0.2 (equally stable)
Haha. OK I see. Thanks for clarifying! My 8.0.2 crashes 24/7, so I wanted to check whether it could be something! Possibly slightly more stable. Guess I have to take a chill pill
I wanted to try it (fresh install with kszaq's 8.2 dtb) but it stucked at the second setup page, I cannot go futher, the next button does nothing.
Will this version work for the mx2 and is there a.tar file to update it. I'm running the 7.'95.3 version which only has kodi 17.0.
Does MX2 use S912?
It uses the amlogic 8726-MC Soc if that makes any sense. What I have installed is your LibreELEC-Amlogic_MX2.arm-7.95.3.tar which works great but that only has kodi 17.0 . Hoping to upgrade to 17.3 if possible.
You probably mean 8726MX. S912 is a much newer chip. I have never built anything for 8726MX. Please look at stick thread, there you'll find links to threads with builds for other Amlogic SoCs: [INDEX] LibreELEC community builds for Amlogic
2 days this version works without any problems. Thank you
Just one problem with this version and with all previous with sound.
After about 20-30 minutes there is a visible audio sync problem for AC3. The sound starts to lag behind.
If I stop the video or PVR channel and start it again than no sync problem and again after 20-30 minutes difference is visible and it becomes bigger.
Does anybody has this problem too? Or any fixes available for this async?
Add:
If Enable Dolby Digital (AC3 ) Transcoding checked than AC3dec_enabled.txt
If Enable Dolby Digital (AC3 ) Transcoding not checked than AC3dec_disabled.txt
Channel openning log: channel.txt
From log looks like it tried to transcode AC3 to DTS-HD in first case. Is it correct?
Anyone tried a proper stream with tvheadend with 8.2? I got some channels in 2160p (25mbit). Hope that the box can run it
Twice tested for about 1.5 hour
First time a small sync issue visible for AC3 after 60-70 minutes.
Second time a small sync issue visible for AC3 after 100 minutes.
This release works much better, please say what did you fix, because in Leia build there is a big async for audio from the first minutes.
I didn't find audio out of sync issue on my MeCOOL BB2 Pro (S912 3GB RAM) even with danxc's 1st 8.2 release. Will update with current release and test again.
With Leia build (wrxtasy) on the same box, audio out of sync issue happened from the very beginning of playback and getting worse and worse. Similar situation happened with Raybuntu's Leia build on Odroid-C2 (tested up to leia5) as well. 720p 8-bit HEVC contents are less susceptible to sync problem while 1080p 10-bit HEVC are the worse. It seems there is no hw acceleration for playback at all, or at least not sufficient.
All my video contents resided on NAS connecting via ethernet using either Samba or NFS protocol.
8.1.1 uploading now.
8.1.1 version from kszaq still have AC3 sync issue.
Returned back to danxc build LibreELEC-S912.arm-8.2-devel-20170722225227-r25975-g47938bbd1.tar
@danxc, could you share the patch to include it to kszaq builds too?
