Thanks for the reply, I have tried both a UK keyboard and onscreen keyboard and can see that the details are correct when you click on show password - any ideas please?
VPN Manager for OpenVPN
- zomboided
- Thread is Unresolved
only thing I can think of, is uninstall the manager, reboot. It should then ask you if you want to run the wizard.to setup the vpn
thank you, have now sorted it, for some reason it didn't like how my password was set up so I changed that and it now works.
when I try to run it I get an error that says it could not authenticate with VPN provider and to check user name/password
Getting the same problem here. I had it set up and working fine with IPVanish, but it simply won't authenticate with NordVPN. I uninstalled the add-on completely, then re-installed via the Zomboided repo. Still no dice. The logs say:
CodeERROR: VPN Mgr:(alternative.py) API call for https://api.nordvpn.com/v1/users/tokens,username=<redacted>&password=********ERROR: VPN Mgr:(alternative.py) Response was <class 'ssl.SSLError'> ('The read operation timed out')The username and password are definitely correct.
Update: And now I'm seeing other things in the logs, including:
Response was 522 Origin Connection Time-out, following by HTML for a web page that seems to suggest a connection failure between Cloudflare and NordVPN, thus:
And my previous attempt resulted in:
And again an HTML page with:
[EDIT] Aaaaand once more, with feeling: having seen some surprising references to IPVanish in the logs (although I now think these were prior to switching the settings to NordVPN), I decided to do a reboot. This time, the authentication failure was simpler, not involving Cloudflare:
Code11:17:30.112 T:1699488672 NOTICE: VPN Mgr : (service.py) Starting VPN monitor service, platform is 2, version is 5.0.711:17:30.118 T:1699488672 NOTICE: VPN Mgr : (service.py) Addon path is /storage/.kodi/addons/service.vpn.manager/11:18:20.256 T:1699488672 ERROR: VPN Mgr : (alternative.py) API call was https://api.nordvpn.com/v1/users/tokens, username=<redacted>&password=********And finally...
As so often happens, just after posting I find a solution.
I downloaded a bunch of configuration files from here: NordVPN
I selected just a few of the .ovpn files and put them in a folder on a USB stick, and plugged the stick into the RPi I'm using as my LibreELEC box.
From the VPN Configuration screen I opted for 'User defined import wizard' and said 'yes' to the stuff about overwriting configurations etc.
I chose the folder/directory option and pointed it at the folder on the USB stick with the .ovpn files.
This left me with a config with 'user defined' instead of 'NordVPN', but still with the same username and password. I could then go into VPN Connections and select the required connections. And it works. Alas, still can't get BBC iPlayer here...
I have an expired Nord account and it works fine right up until the connection to the VPN service.
Who knows why it's not working for you, you've shared select entries you think are important from a log which may or may not have debug enabled.
I have the same issue, even if I use a UK connection, so I go into the settings to disable vpn with iplayer
That's a pretty snotty attitude. I'm not an expert in this stuff and have gone to some trouble to provide information that I thought might be pertinent. The simple fact is, when I tried the NordVPN option provided, it didn't work. I found a work-around that did and shared that information. So for you to brush this off with, 'hey it works for me...' is arrogant and unhelpful.
You're right. I should not have tested my account at all. And I should have guessed at your issue from the excellent debug you provided. Stop being so self-entitled. This is free software, which I'm happy for you not to use.
Recently acquired a new VPN, from GhostPath, unfortunately when I import the ovpn file I get the error "Killall conflicts with ping"
Will grab the full log later if this isn't enough
Code -
I think the error is 'keepalive conflicts with ping'. They both do kinda the same thing, keeping the connection active. You can disable adding ping by using the settings GUI (I think it's in the advanced tab), or you can delete keepalive from the the file you're sharing.
I will give it try, thanks
If you resolve an IP to the ASN block that owns it you can tell (with reasonable accuracy) whether an IP is domestic or used for hosting, and similar to Netflix the BBC has started to routinely and aggressively block IP ranges associated with commercial hosting services. Combined with basic source IP monitoring (so you can see concentrations of connections coming from the same VPN exit nodes) it's quite simple to block VPN service providers.
Hello, thanks for the great addon.
I have used it for a year or so with no issues however now it's not working. When connecting I get "Error connecting to first VPN, something unexpected happened. Check log etc..."
From the log file, this line several times:
Cannot resolve host address: mel-c01.ipvanish.com:443 (Name or service not known).
Any ideas? I am illiterate with the code side of things.
Update: I seem to be able to connect (to a different server, not preferred location) but it has "potential dns issues" and wont allow internet activity.
Looks like that server no longer exists. I'll update IPVanish servers in the next day or two and you'll see a notification on connect that they're available.
Thanks!
Hi,
Thanks for this plugin. I try to use it for PureVPN. It's working with User Defined I have only small issue :
- I get the list of .ovpn files for UDP and TCP from PureVPN (I tooke the zip file for OpenVPN setting). In this list, I have also a Wdc.key file. When I import the list, I can see that some path in the .ovpn are updated correctly but not the line with the .key file and I have also a warning about the pass.txt file after changing this its working (set chmod 777 to pass.txt)
So, my question is : can you update the import to change the line:
tls-auth Wdc.key 1 to tls-auth /storage/.kodi/addons/service.vpn.manager/Wdc.key 1
and check the warning about the authorisation on pass.txt
Thanks you
romuald I agree that the User Import should resolve that line properly. Thanks for mentioning this, I've opened an issue on GitHub here to fix this User Import misses some files · Issue #211 · Zomboided/service.vpn.manager · GitHub
Until then, you can edit the files that are generated to the userdata directory to correct them with the right path yourself.
Regarding any warnings, it's up to you to ensure that you're happy with the way the User Defined is set up and determine whether it's an issue. The reason for User Defined existing is to allow a way of using unsupported providers without me having to repeatedly spend time and effort ensuring they work. Or more prosaically in the case of PureVPN, support their shoddy service for free.
Thanks for the ticket.
I manually change the line and it's working fine.
