I've made this ugly thing to handle Amiga zip's with several disks: LibreELEC.tv/fs-uae.start at le82 · escalade/LibreELEC.tv · GitHub
Sx05RE v1.8.6 Emulationstation+Lakka+Kodi
niabi -
February 10, 2017 at 11:29 PM -
Thread is Resolved
You can find a newer version for the S912 in my github, I sent you a PM with a link to it
Thank you very much,I'll try it as soon as I can
really appreciate it
Nice! I will check it out ASAP and hopefully I can implement it
Thanks! -
Tested your new version, it worked great with my S912 a Mecool M8S Pro L, Thank you so much!!!
Any chance this version will be "upgradeable" with a file in some folder?
Also MAME2010 is not working with my 2010 roms(they work well in windows), but MAME2003 is working great with the roms it support
Thanks again
Thanks again
That is the idea.
Can you open an issue on Github so I can check the mame2010 problem?
That is the idea.
Hi, I see that the included cores are in /tmp/cores/
how can I download other cores? is there a lakka build repo for s912? the mame2010 is the one Im interested the most
Thanks in advance
Where can I get the ,tar to upgrade to V1.8.6?
If you have the .img you can put that into the update folder. Thats works too.
Tried that but box would not boot up.
Sorry, that is the only way to upgrade, I don't have the TAR since it was not needed.
Other thing, i've figure out a way to detect and autoconfigure the controllers for DreamCast - so if you have more than one controller with a config (also made a script to create those configs files) the system detects and changes the emu.cfg to correspond to the correct controllers, and a script to make a .UAE for amiga games (works fine, but only tested ECS games) that allows to run a amiga game from emulationstation and get all floppys loaded, way simpler than the CHDs that load faster, but also is simpler to add games this way - put the adf (or ziped adf) games in the amiga directory, when select the ADF the script search for other games corresponding to other floppies (based on disk N of N in the name to work), then create a temp.uae and loads it on the emulator, not need to creating all uae files one by one..
Looking fowards for help, sorry for the poor english and again, great work on this!
I am very interested in this scrip, care to send it to me ? or is it somehwere online?
Great work.
Now what is the difference between your v1.8.6 and ScottElec from mxqproject March 2018 videos?
Any plans to add a package manager, e.g. Entware opkg as in CoreElec?
ScottElec is a modified version of Sx05RE 1.8.3.
Ok ! So the versions here are more advanced?
Also any plans for a package manager in here, not present in LibreElec but in CoreElec which apparently has better tweaks for S905 boxes?
@niabi Recently they have released a core for reicast for arm in lakka.
Hi,
how can I find out which version of Sx05RE I've installed?
I once have downloaded MXQ Project but only copied the Retroarch folder because I liked the possibility to run RA out of my Kodi addon menu. However the MXQ Project is from last year and I don't know how to update my Retroarch files. Kodi shows me that the current version is 7.0.2-J08. Whatever this means. Does anybody know how to update my Retroarch files to the latest Retroarch files from Sx05RE v1.8.6? There is a bug which makes it impossible to play multidisk games in pcsx_rearmed and maybe it works better in the latest version. I hope so because I already asked for help in libretro forum, on github and reddit but nobody cares. I'm running out of ideas. All the good RPGs are multidisk games and I can't play none of them
Help me please -
Kupo91 did you tried to convert your psx multidisc games to PBP with PSX2PSP? This allows to join multidisc (up to 5 discs) games in one file, playable on any psx emulator....
Hi,
Help me please -
I'll put it online as sun as possible (sorry for the delay on this answer, didn't return to the forum sinse than), it reads the inputs with evdev and rewrite the retroarch config file to match the controllers detected, will try to paste here (but probably the code will look something odd..):
Python
Display Moreimport evdev import time from evdev import InputDevice, categorize, ecodes from asyncore import file_dispatcher, loop import string from select import select import zipfile import os import subprocess import sys def shellquote(s): return "'" + s.replace("'", "'\\''") + "'" jogo = sys.argv[1] arq1 = open('/storage/.config/reicast/base_emu.cfg','r') inicio = arq1.read() arq1.close() i = 0 e = 0 devices = [evdev.InputDevice(fn) for fn in evdev.list_devices()] for device in reversed(devices): entrada = device.phys if(entrada[0:3]=='usb'): i = i+1 if(i<3): e = e+1 print(device.fn[-1]) inicio = inicio.replace('idctrl'+str(i),device.fn[-1]) inicio = inicio.replace('mapjoystick'+str(i),device.name+'.cfg') inicio = inicio.replace('numofplayers',str(e)) inicio = inicio.replace('evdev_mapping_2 = /storage/.config/reicast/mapjoystick2','') inicio = inicio.replace('idctrl2','-1') arq2 = open('/storage/.config/reicast/emu.cfg','w'); arq2.write(inicio) arq2.close() comando = '/usr/bin/reicast '+shellquote(str(jogo)) subprocess.call(comando,shell=True)-----------------------------------------------
The base_emu.cfg
Display More[audio] backend = auto disable = 0 [config] Debug.SerialConsoleEnabled = 0 Dreamcast.Broadcast = 4 Dreamcast.Cable = 3 Dreamcast.RTC = 1543276812 Dreamcast.Region = 3 Dynarec.Enabled = 1 Dynarec.idleskip = 1 Dynarec.unstable-opt = 0 aica.LimitFPS = 1 aica.NoBatch = 0 aica.NoSound = 0 bios.UseReios = 0 pvr.MaxThreads = 3 pvr.Subdivide = 0 pvr.SynchronousRendering = 0 pvr.rend = 0 rend.UseMipmaps = 1 rend.WideScreen = 0 ta.skip = 0 [input] evdev_device_id_1 = idctrl1 evdev_device_id_2 = idctrl2 evdev_device_id_3 = -1 evdev_device_id_4 = -1 evdev_mapping_1 = /storage/.config/reicast/mapjoystick1 evdev_mapping_2 = /storage/.config/reicast/mapjoystick2 joystick_device_id = -1 [players] nb = numofplayers [reios] ElfFile = [testing] ta.HashCheckFile = ta.HashLogFile = [validate] OpenGlChecks = 0---------------------------------------------------------------
The game path + name must be passed as argument 1, and the controllers must be prev configured, done the following (and like all the rest, a uggly written) script to map, this must be acessed by shell
Python
Display Moreimport string import evdev import time from evdev import InputDevice, categorize, ecodes from select import select i = 0 entrada = 'not' devices = [evdev.InputDevice(fn) for fn in evdev.list_devices()] for device in devices: entrada = device.phys if(entrada[0:3]=='usb'): i = i+1 entrada = device.name guardar = entrada dev = InputDevice(device.fn) print('Controle detectado: '+entrada) listed = [] e=0 print('Pressione A (botao abaixo)') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) botA = event.code print(event.code) e = 1 e = 0 print('Pressione B (botao direito)') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) botB = event.code print(event.code) e = 1 e=0 print('Pressione X (botao esquerdo)') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botX = event.code e = 1 e=0 print('Pressione Y (botao acima)') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botY = event.code e = 1 e=0 print('Pressione DPAD UP') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) axDY = event.code e = 1 e=0 print('Pressione DPAD LEFT') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) axDX = event.code e = 1 e=0 print('Pressione START') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botSTART = event.code e = 1 e=0 print('Pressione SELECT (sair do emulador)') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botSELECT = event.code e = 1 e=0 print('Pressione L1') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botL1 = event.code e = 1 e=0 print('Pressione R1') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01,03]): if(event.code not in listed): listed.append(event.code) print(event.code) botR1 = event.code e = 1 e=0 axANY = 'axANY' axANX = 'axANX' print('Deseja configurar o analogico? Pressione A para Nao ou B para SIM') while e==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [01]): if(event.code == botA): e = 1 if(event.code == botB): print('Mova o analogico para a esquerda'); f = 0 while f==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [03]): if(event.code not in listed): listed.append(event.code) print(event.code) axANX = event.code f = 1 print('Mova o analogico para cima'); f = 0 while f==0: r,w,x = select([dev], [], []) for event in dev.read(): if(event.type in [03]): if(event.code not in listed): listed.append(event.code) print(event.code) axANY = event.code f = 1 e=1 arq = open('/storage/.config/reicast/base_config_ctrl.cfg','r') config = arq.read() arq.close() config = config.replace('botL1',str(botL1)) config = config.replace('axDY',str(axDY)) config = config.replace('botR1',str(botR1)) config = config = config.replace('axDX',str(axDX)) config = config.replace('nomectrl',str(guardar)) config = config.replace('botSELECT',str(botSELECT)) config = config.replace('botB',str(botB)) config = config.replace('botA',str(botA)) config = config.replace('botX',str(botX)) config = config.replace('botSTART',str(botSTART)) config = config.replace('botY',str(botY)) config = config.replace('axANY',str(axANY)) config = config.replace('axANX',str(axANX)) config = config.replace('axis_x = axANX','') config = config.replace('axis_y = axANY','') arq = open('/storage/.config/reicast/'+str(guardar)+'.cfg','w') arq.write(config) arq.close() print('Configurado com sucesso')---------------------------------------------------------------------------
The base_config_ctrl.cfg:
Display More[compat] btn_trigger_left = botL1 axis_dpad1_y = axDY btn_trigger_right = botR1 axis_dpad1_x = axDX [emulator] mapping_name = nomectrl btn_escape = botSELECT [dreamcast] btn_b = botB btn_a = botA btn_x = botX btn_start = botSTART btn_y = botY axis_y = axANY axis_x = axANX--------------------------------------------------------
The text written in shell is in portuguese, but is understandable (this word exists?) by reading the code itself...
All the files are in /storage/.config/reicast/, as well as the controllers config files..
The indentation (those are python scripts) where lost here, will try to post id in github..
