Thanks for the responses chaps. It must be something my end then, as I have x 3 Nexbox A95x S905X boxes and all 3 freeze when trying 4k movies. Yet if reinstall SPMC on android they play 4k perfect. Weird.
Best settings for 4K HDR playback?
Stige -
January 31, 2017 at 3:16 PM -
Thanks for the responses chaps. It must be something my end then, as I have x 3 Nexbox A95x S905X boxes and all 3 freeze when trying 4k movies. Yet if reinstall SPMC on android they play 4k perfect. Weird.If you're using NFS, I would recommend to try to mount NFS at the OS level (Mounting network shares - OpenELEC).
Without changing anything and using the same NFS server, I get sluggish performance using the native NFS implementation in Kodi while it works perfectly if I use the same server at the OS level.Something similar: NFS (libnfs) Performance
R4W,
Thanks again for reminding us to do this. I really learned the hard way on this one. It would sometimes work but always give me problems when I reflashed the new ROM. This always works perfectly without messing with it for hours. I'd suggest anyone else with mysterious buffering issues, don't be stupid like me, do like r4w says first.
I'm mapping the shares on OS level, but no files are listed inside the folders. I checked my NAS and permissions look OK, created a new share just in case, I can access the shares from my Windows PC and my Android phone, and I can access them on Kodi/LibreELEC via SMB or UpNP, but not NFS.
I'm currently automatically mapping them at boot. I tried to use # mount -t nfs 192.168.0.9:/Movies /storage/movies2/ -o nolock via SSH and it returned an error which is probably the cause of the issue:
mount: 192.168.0.9:/Movies failed, reason given by server: Permission denied
mount: mounting 192.168.0.9:/Movies on /storage/movies2/ failed: Bad file descriptorThe IP for the NAS is correct and so is the share, but even if I change that to an incorrect one it doesn't make any difference and I get the same error.
I'm not a Linux user so any help is welcome.
Syntax is OK
Did You create the local folder /storage/movies2 ?
Is 192.168.0.9:/Movies the full path to folder on NAS ?command to mount my NAS
where 192.168.0.41:/c/backup is full path to NAS-share and /storage/mnt is local folder on my boxcheck:
I ended up giving up on LibreELEC and going to an Android TV build for proper HDR support.
Pros: HDR/10 bit output/colorspace switching actually works with an Android TV port and spmc. It looks indistinguishable from my internal player.
Can use some Android TV apps as spmc launcher shortcuts.Cons: No resolution switching, so dealing with poor upscaling on anything that isn't 4k.
Brightness bug is back on boot.
Needed to root and use PassthroughFix.apk to fix passthrough clipping.
SPMC is currently only available as a Jarvis build.I'm very tempted to use separate boxes with LibreELEC and Android on different inputs so I can have proper HDR/10bit output/colorspace switching, and also resolution switching for decent upscaling.
Syntax is OK
Thank you for your reply
All paths were correct and I tried all sorts of combinatons. Seems that it might be something to do with my NAS setup.
I was able to get it working using cifs and shares are properly mapped at reboot. Hopefully that should take care of the bandwidth issues for me.
Adapter works oob with LE 7.95b
Iperf reports 180-330 Mbitjellyfish-140-mbps-4k-uhd-hevc-10bit.mkv runnig smooth
BTW:
Adapter is not working with Stock AndroidSorry for resurrecting this old thread.
I have an adapter with the same chip, but I can`t get it to work. Well, it works - but only 100 Mbit. (Last version from kszaq).
Here is what I get:
LibreELEC:~ # ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Link detected: yes
LibreELEC:~ # ethtool -i eth1
driver: r8152
version: v1.04.0 (2014/01/15)
firmware-version:
expansion-rom-version:
bus-info: usb-xhci-hcd.0.auto-2.4
supports-statistics: no
supports-test: no
supports-eeprom-access: no
supports-register-dump: no
supports-priv-flags: no
LibreELEC:~ # modinfo r8152
filename: /lib/modules/3.14.29/kernel/drivers/net/usb/r8152.ko
license: GPL
description: Realtek RTL8152/RTL8153 Based USB Ethernet Adapters
author: Realtek linux nic maintainers <nic_swsd@realtek.com>
alias: usb:v04E8pA101d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp8153d*dc*dsc*dp*ic*isc*ip*in*
alias: usb:v0BDAp8152d*dc*dsc*dp*ic*isc*ip*in*
depends:
intree: Y
vermagic: 3.14.29 SMP mod_unload aarch64
Seems right?! But only 100baseT/Full
The Adapter is indeed a r8153 - pluged it in my desktop and it works fine. 1000 Mbit. I have only a Windows 10 machine to test here atm, but driver says its a realtek 8153
Any ideas?
USB Network adapter = usbnet0
Settings for usbnet0:
1000baseT/Half 1000baseT/Full
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 2
Supports Wake-on: pg
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
Not necessarily.
My RT8153 adapter shows up as eth1 and my AX88179 adapter shows up as usbnet0.
puked:
I heard a fake rt8153 adapter which was 100 mpbs only probably contained 8152 chip
as I said - I tested it on my windows machine and it is indeed gigabit - does not just say so, but gives me gigabit speeds. Copied a file over smb and got ~40 MB/S. ID hints to 8153, too
edit: Works on a raspi (raspbian) ootb - gigabit here, too.
- Official Post
There were a couple of scattered Krypton attempts by SPMC, but it is likely to remain that way for some time to come, as the SPMC developer Koying has recently moved over to the MrMC team.
Also, HDR is still a work-in-progress in Kodi Leia. -
ASIC adapter
905X-WZ:~ # ethtool -i usbnet0
driver: asix
version: 22-Dec-2011
firmware-version: ASIX AX88178 USB 2.0 Ethernet
bus-info: usb-xhci-hcd.0.auto-1
supports-test: no
supports-eeprom-access: yes
Realtek Adapter
905X-AZ:~ # ethtool -i eth1
driver: r8152
firmware-version:
supports-test: no
905X-AZ:~ # ethtool eth1|grep -i speed
Speed: 1000Mb/s
hm
your adapter uses the r8152.ko module, too. as expected.
lsusb gives me:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 035: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 001 Device 034: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 033: ID 13fe:5500 Kingston Technology Company Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
but:
Speed: 100Mb/s
damn- I have no idea
thank you
905X-AZ:~ # lsusb
Bus 001 Device 002: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
You are using an usb-hub, try to connect direct to onboard usb port -
I would =)
but - the lan port is part of that hub
seems like I need another adapter.
I´m using simple USB network adapter(s)
I can try to test my combi adapter - 3port USB3 & Gb network
driver: r8152
firmware-version:
bus-info: usb-xhci-hcd.0.auto-1.1
supports-test: no
905X-AZ:~ # lsusb
Bus 001 Device 003: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Speed: 1000Mb/s
905X-AZ:~ # ethtool eth1|grep -i duplex
Duplex: Full
Your adapter fails
