  • kszaq Thanks for your great work with this image. I'm using it on the Wetek Hub. Tried the Krypton version a couple of times, but not working as well as the Jarvis Version.
    The only problem I have is from time to time breaking sound, it simply has hickups. I don't know how to describe it better, especially on live tv. Any setting I can change or anything I can do about it? The Hub is connected directly to TV nd no passthrough is activated.
    Update: installed the Audio DSP basic addon, all strange breaks in Audio are gone, just that the Audio DSP basic addon does not stay enabled after reboot.
    Edited once, last by vlaves (May 14, 2017 at 4:45 PM).
    its the best image so far and stable. But i cant get work wifi module in my tronsmart telos vega s905. Wifi doesnt work . If i put any of your trees it wont boot onto LE. But if i let it stay by default Tree i get boot onto LE.
    Please help me finding the right device tree for my Box.
    best regards
    tunay
  • waiting for replys
    You had one that suggested you actually try them yourself. Not interested in that idea?
    Having tried all the dtb's yourself, without success, indicates that the issue is NOT to do with the device tree.
    Perhaps you should upload your logs for kszaq to take a look at ;)
    Edited once, last by Poida (May 16, 2017 at 11:51 AM).
  • I know this is an old post, but I have recently been testing FLAC 16bit as an alternative to untouched DTS-HD MA tracks to save some space (it works great btw).
    FLAC audio (or the decoding to PCM) introduces an additional delay for me.
    The 175ms are perfect to me for bitstreaming DTS (HD) and Dolby Digital (+TrueHD) etc., but a FLAC track decoded to multichannel PCM apparently adds another 175ms (or at least something close to that).
    Is it possible to add another exception to the advancedsetings for a specific audio track type?
    Something like (pseudo:(
    <video>
    <latency>
    <delay>0</delay>
        <audio codec>
    <type>flac</type>
    <delay>175</delay>
    </refresh>
    </latency>
    </video>
    Can somebody help me with this?
    Also, the FLAC sometimes has weird distorted noise to it and a beep when it starts.
    Is there a fix for that?
    It's normally gone when I start a DD file and go back to the FLAC file...
  • What is the difference between the device tree "gxl_p212_2g_nand.dtb" and the "gxl_p212_2g.dtb"? Thanks for your help.
    How to Link #1
    S905X: Device trees for these boxes start with gxl. You can leave a tree that is already present on SD card (fresh install only) or choose one according to your RAM amount. If internal memory of your box is not visible when trying to install to internal memory, try a device tree with _nand suffix.
  • i am not able to start kodi with 7.0.3.12k kszaq - ping me if you need more logs
    M9-4K:~/.kodi/temp # /usr/lib/kodi/kodi.bin --standalone
    ERROR: Unable to create GUI. Exiting
    Segmentation fault (core dumped)
    12:49:42 T:4116152896 NOTICE: special://profile/ is mapped to: special://masterprofile/
    12:49:42 T:4116152896 NOTICE: -----------------------------------------------------------------------
    12:49:42 T:4116152896 NOTICE: Starting Kodi (16.1 Git:c327c53). Platform: Linux ARM (Thumb) 32-bit
    12:49:42 T:4116152896 NOTICE: Using Release Kodi x32 build
    12:49:42 T:4116152896 NOTICE: Kodi compiled May 4 2017 by GCC 5.3.0 for Linux ARM (Thumb) 32-bit version 3.14.29 (200221)
    12:49:42 T:4116152896 NOTICE: Running on LibreELEC (community) - Version: 7.0.3.012k, kernel: Linux unknown CPU family 64-bit version 3.14.29
    12:49:42 T:4116152896 NOTICE: FFmpeg version: 2.8.6
    12:49:42 T:4116152896 NOTICE: WARNING: unsupported ffmpeg version detected
    12:49:42 T:4116152896 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
    12:49:42 T:4116152896 NOTICE: ARM Features: Neon enabled
    12:49:42 T:4116152896 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
    12:49:42 T:4116152896 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
    12:49:42 T:4116152896 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
    12:49:42 T:4116152896 NOTICE: special://home/ is mapped to: /storage/.kodi
    12:49:42 T:4116152896 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
    12:49:42 T:4116152896 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
    12:49:42 T:4116152896 NOTICE: Local hostname: M9-4K
    12:49:42 T:4116152896 NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
    12:49:42 T:4116152896 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
    12:49:42 T:4116152896 NOTICE: load settings...
    12:49:42 T:4116152896 NOTICE: Found 2 Lists of Devices
    12:49:42 T:4116152896 NOTICE: Enumerated ALSA devices:
    12:49:42 T:4116152896 NOTICE: Device 1
    12:49:42 T:4116152896 NOTICE: m_deviceName : default
    12:49:42 T:4116152896 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
    12:49:42 T:4116152896 NOTICE: m_displayNameExtra: PCM
    12:49:42 T:4116152896 NOTICE: m_deviceType : AE_DEVTYPE_PCM
    12:49:42 T:4116152896 NOTICE: m_channels : FL,FR,UNKNOWN1,LFE,BL,BR,FC,BC,BLOC,BROC
    12:49:42 T:4116152896 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
    12:49:42 T:4116152896 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
    12:49:42 T:4116152896 NOTICE: Device 2
    12:49:42 T:4116152896 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
    12:49:42 T:4116152896 NOTICE: m_displayName : AML-M8AUDIO
    12:49:42 T:4116152896 NOTICE: m_displayNameExtra: HDMI
    12:49:42 T:4116152896 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
    12:49:42 T:4116152896 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
    12:49:42 T:4116152896 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
    12:49:42 T:4116152896 NOTICE: Enumerated PULSE devices:
    12:49:42 T:4116152896 NOTICE: m_deviceName : Default
    12:49:42 T:4116152896 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
    12:49:42 T:4116152896 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
    12:49:42 T:4116152896 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
    12:49:42 T:4116152896 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
    12:49:42 T:4116152896 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
    <?xml version="1.0" encoding="UTF-8" ?>
    <advancedsettings>
    <showexitbutton>false</showexitbutton>
    <cputempcommand>cputemp</cputempcommand>
    <gputempcommand>gputemp</gputempcommand>
    <video>
    <latency>
    <delay>0</delay>
    <refresh>
    <min>23</min>
    <max>24</max>
    <delay>175</delay>
    </refresh>
    </latency>
    <busydialogdelayms>750</busydialogdelayms>
    </video>
    <samba>
    <clienttimeout>30</clienttimeout>
    </samba>
    <network>
    <readbufferfactor>4.0</readbufferfactor>
    </network>
    <pvr>
    <minvideocachelevel>5</minvideocachelevel>
    <minaudiocachelevel>20</minaudiocachelevel>
    </pvr>
    </advancedsettings>
    12:49:42 T:4116152896 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
    12:49:42 T:4116152896 NOTICE: Default DVD Player: dvdplayer
    12:49:42 T:4116152896 NOTICE: Default Video Player: dvdplayer
    12:49:42 T:4116152896 NOTICE: Default Audio Player: paplayer
    12:49:42 T:4116152896 NOTICE: Disabled debug logging due to GUI setting. Level 0.
    12:49:42 T:4116152896 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
    12:49:42 T:4116152896 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
    12:49:42 T:4116152896 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
    12:49:42 T:4116152896 NOTICE: Loaded playercorefactory configuration
    12:49:42 T:4116152896 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
    12:49:42 T:4116152896 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
    12:49:42 T:4116152896 NOTICE: Running database version Addons20
    12:49:42 T:4116152896 NOTICE: ADDONS: Using repository repository.xbmc.org
    12:49:42 T:4116152896 NOTICE: ADDONS: Using repository repository.libreelec.tv
    12:49:42 T:4116152896 ERROR: AML: no rw on /sys/class/ppmgr/ppmgr_3d_mode
    12:49:42 T:4116152896 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
    12:49:42 T:4116152896 ERROR: EGL error in InitDisplay: 3003
    12:49:42 T:4116152896 ERROR: InitWindowSystem: Could not create display
    12:49:42 T:4116152896 FATAL: CApplication::Create: Unable to init windowing system
  • 7.0.3.012l uploaded: subtitles security patch backport applied & back to MM kernel.
    kszaq My daily user box is running 7.0.3.012j flawlessly on my 1080p TV.
    Apart from this subtitle fix, what else of any significance has changed in the 7.0.3.012l ?
  • kszaq My daily user box is running 7.0.3.012j flawlessly on my 1080p TV.
    Check the changelog! :)
    7.0.3.012l
    kernel is back to Marshmallow
    With 012j you have Marshmallow, too, so there should not be any change, I guess.
