Pi 3: wlan power-save enable by default
  • Hello,
    my "problem" is, that the power-save feature of the integrate wlan on Raspberry Pi 3 is enable by default in LibreELEC 7.0.0 and maybe, it's a bug?
    Last week a have "upgraded" from Rasperry Pi 2 to Pi 3 and using the same SD-Card with LibreELEC 7.0.0 (which was upgraded from OpenELEC 6.0.3 on Pi 2). But I'm not sure, maybe the following issue is solved in LibreELEc 7.0.0 (with a "fresh" installation, without ballast from OpenELEC or Pi2).
    I have found the solution in the OpenELEC forum (OpenELEC Mediacenter - OpenELEC Forum - Raspberry Pi 3 wlan issues (1/1)). But the name of the addon in LibreELEC 7.0.0 is "Network Tools".
    The current power-save status of the integrate wlan in the Pi 3 can see with the following command (by default it's activate):
    1. LibreELEC:~ # /storage/.kodi/addons/virtual.network-tools/bin/iw wlan0 get power_save
    2. Power save: on
    With the command
    1. LibreELEC:~ # /storage/.kodi/addons/virtual.network-tools/bin/iw wlan0 set power_save off
    you can disable it. But it's only temporary. After a restart of LibreELEC it's enable again.
    With the script "autostart.sh" (it should contain the last command) you can do this automaticly. You have to put it on the SD-Card (/storage/.config/). Now the power-saving of the integrate wlan on Pi 3 is disable by "default".
    But is this a bug? Can somebody confirm this?
    For me it's working now and I have no problems, but maybe other users have same problem and that's why I have open this topic.
    Thank you.
  • Powersave *is* disabled, but in the kernel, so iw isn't aware of it.
    You should the message "brcmfmac: power management disabled" in dmesg log.
  • Ok, I can see the message, but without disable the power-save with "iw" the wlan goes in power-save modus after a few minutes (e.g. I can't open SSH, sftp or samba connections anymore and the internet-connection on Kodi is very slow).
    After I have disable the power-save mode with "iw" everything is fine and I have absolutly no problems with wlan anymore!
    [EDIT]
    Here is my dmesg log:
    [Bash] LibreELEC:~ # dmesg log [ 0.000000] Booting Linux on physical CPU 0x0 [ - Pastebin.com
    Edited once, last by kar82 ().
  • Hello,
    on LibreELEC (official) Version: 7.0.2 (on RPI3)
    first install -> Libreelec Addons/Program Addons/Network Tools
    reboot
    logon via ssh and test -> iwconfig
    wlan0 shows up like -> Power Management:on
    then -> nano /storage/.config/autostart.sh
    add -> iw wlan0 set power_save off
    -> save and exit
    -> reboot
    wlan0 shows up like -> Power Management:off
    ...maybe the solution
  • This worked perfect for me. I had to install iw and iwconfig through the unofficial openelec repo but was able to get this working by creating the autostart.sh and pointing to the location of my iwconfig ( /storage/.kodi/addons/tools.iw/bin/iw wlan0 set power_save off )
    Edited once, last by Yabbo ().
  • Thanks...done it here too...wasn't sure if it was still an issue...but it was and now is working fine..
