Demetris, I have M8S PLUS box with Ap6330 bt/wifi chip.
When I tried to upgrade to Libreelec 8.0.1 with your 8.0.1 m8s plus image with .tar (from Libreelec 7.0.2) I ended this way:
Do you have a clue what went wrong?
This mean it works?
[hr]I would try S82 1st.
It don't work for me. And I like a new image for m8s
Verstuurd vanaf mijn SM-G925F met Tapatalk
Demetris
I've noticed this on the older build I had, but the problem remains on the new build as well.
I have a M8S+, 2G/8GB, and after it starts one core is always at 100% load. This makes the box slower than it can be and also heats up the CPU quite a bit.
The process that causes this is 'brcm_patch+', I assume that it's a patch for wifi.
Is it possible to fix this or add a watchdog for this process to be killed off automatically? I can kill it from the terminal and everything works fine until the next reboot.
While idle:
While watching a Live IPTV stream after I kill the process:
Display More
Demetris
Is it possible to fix this or add a watchdog for this process to be killed off automatically? I can kill it from the terminal and everything works fine until the next reboot.While idle:
Hey man you are NOT using my image ask alex for a fix and don't try to confuse me as i am supporting many devices and false reports are getting me out of my way.
Display MoreHi there, I've tried the image on my M8S PLUS it works great but...
Remote not working
Wifi not working
No Bluetooth
No Librelec settings on the main kodi screen anymore? So I can't test wifi or BluetoothCPU = ARMv7 Processor rev 1 (v71)
Hardware: Amlogic Meson8
GPU = Mali-450 MP
CPU temp 59 CCan you try the M8S-PLUS image and report back if it works on your box? If not i will prepare a new image specific for plain M8S(S812)
hi guys, I am completely new to this.
I have a M8 Amlogic S802 (2GB RAM / 8GB Storage) running OpenELEC 6.0.3 (Kodi 15.2 Isengard). I would like to upgrade to Kodi 17.1 Krypton and someone suggested to try LibreELEC.
Is there a LibreELEC ROM for my device?
If so, where can I get a copy of it and how do I apply the ROM?
Are there any known issues with the ROM?
I look forward to your response.
Thanks,
Khaz
PS - I should say I have limited Linux skills so any step-by-step guides / links would be most appreciated.
Download M8 tar image place it i update folder and reboot
Sent from the Island of Venus
Hi Demetris ! You latest release works well on my MXIII 2G box ! wifi and bluetooth are ok ! Thanks a lot for your great work ! Have a nice easter !
Install the newest android image to get the bootloader then update to openelec from zip file then use .tar from my release to update to
Actually this is what I did to start with. It was a new box with stock Android on it. I installed Codesnakes 6.0.0.2 OE through recovery, booted, then copied the LE tar to the install directory and installed. I will try it again. Is there another OE that would be better suited to this process?
Nope you dont need to re do it
How come you guys had such an easy time? My librelelec 7.0.2 was working great with 16.1; I put his file in the /storage/.update folder with that .nocompat file I created; rebooted the MXIII 2G/8G and remote doesn't work; I don't have LibreElec in the koFi SYSTEM menu anymore so I can't check for wifi or bluetooth; any ideas of what I did wrong or how to fix this?
Should I go back to android and start over?
Which file did you use? I have the same box did the same thing and don't have wifi or Bluetooth and remote not working.
Added support for M8S(S812) Images are up for test.
- LibreELEC-S8X2.arm-8.0.1-M8S
Enjoy.
Download M8 tar image place it i update folder and rebootSent from the Island of Venus
I tried this is and now the device hangs....I think my device has been bricked ![]()
I have attached a picture of the last command line that comes up.
any help will be much appreciated
I tried this is and now the device hangs....I think my device has been brickedI have attached a picture of the last command line that comes up.
you must clean your database use something like
really sorry for the stupid question but how do I do that?
I cant the ip address so doubt I will be able to ssh, would appreciate any advice from anyone out there
[hr]I cant the ip address so doubt I will be able to ssh, would appreciate any advice from anyone out there
managed to figure out the ip address, and deleted the contents of the database folder under userdata which seemed to fire up kodi.
only issue now is that my remote control has stop being recognised...is this a known issue? if so, is there a work around.
once again, apologies for the barrage of questions.
Read thread
I’ve updated from ‘LibreELEC-S802.arm-8.0.1-MXIII-1G’ to you last version ‘LibreELEC-S8X2.arm-8.0.1-MXIII-1G’ today.
The upgrade worked fine, to only thing I had to do was crating the ‘.nocompat’ file in update folder.
After the update the remote didn’t work. I did a find for a remote.conf and it was not there in the whole filesystem. I guess the file was deleted during the upgrade process. I copied a backup of remote.conf via Samba into the ‘Configfiles’ folder, rebooted the box and remote worked again.
Enjoy.
Gave it a go with the ever-stuborn OTT M8S 2g/8g w/BCM4335.
Unfortunately, it hung on the boot logo after copying the .tar to /storage/.update and rebooting. I couldn't get it to install using the .zip/factory_update_param.aml in TWRP either.
Regardless, continued thanks for all your hard work for this community. Have a good Easter! ![]()
