afl1 Any chance you can share the Kodi patch?
Source code: GitHub - afl1/LibreELEC.tv at 8.1.8
I guess that majority of the users are running on the 8.2 (8.1.x) builds now. Is it still needed following config ?
- for every standard Maximum PIDs: 26
Limiting PIDs to 26 improve scanning, but it isn't necessary.
I think low frequency is 20 Hz. Sorry, you have to better specify your issue and provide debug logs.
Pls, read [READ FIRST] Reporting bugs.
Really, sorry, I'll post the log as soon as possible.
But one doubt, in this case would have to send tvheadened log. Right?
Because it does not even open the channel, many errors of continuity ....
Of course complete tvheadend log with debug options: mpegts,linuxdvb is necessary.
Hi, I installed LibreElec to nand on my Kii Pro and I am struggling to revert back to android.
I've tried installing various official and unofficial firmwares using both usb and and sd card, however it just hangs on the amLogic screen.
Excuse me if this is the wrong place to post this.
EDIT: It seems as though I have lost recovery as I tried to reboot recovery over ssh and it gives me the same screen.
Thanks.
Evet, bütün kanalları seyredebiliyorum.
Olmazsa pazar ya da pazartesi birebir yardımcı olabilirim, dilersen.
Yes, I can watch all the channels.
If not, I can help you on Sunday or Monday.
Best regards...
I tried everything, replaced the cable with better and newer one, fine-tuned the satellite dish but DVB-S2 is still unstable for most channels, sometimes they work, sometimes they don't. It seems like the device sometimes is not able to lock onto the signal.
These are signal and quality levels I get from ATV HD (original firmware)
Could you share yours?
Where can I find the latest version for KII Pro? I always looked on the front page, but the last compilation is from 2017-06-22. It would be this same
? LibreELEC-S905.arm-8.0-8.0.2c-I.img.gz
Try this !!
anyone heard something about enigma2 for k1 pro?
Yeah, there are a lot of info over 4PDA.ru forum -
Russian guy rocks, i heard first guy import openelec to amlogic is alex, first guy hacked psp darkalex, and one of the ps3 hacker guy alexander igorekov ![]()
Testing build corresponding LE 8.1.9:
LibreELEC-S905.arm-8.2-devel-201710051440-gd562e8e-I.img.gz
LibreELEC-S905.arm-8.2-devel-201710051440-gd562e8e-I.tar
Build is prepared for KI Pro, for other models replace dtb.
In this test build is improved channel zapping (speed and stability).
Sources: GitHub - afl1/LibreELEC.tv at 8.1.9
Display MoreTesting build corresponding LE 8.1.9:
afl1 I don't know what you've done but i just did a FRESH Install of this Test Build on my K1 Pro and for the
FIRST Time EVER
I was able to FIND ALL MUXES in Melbourne Australia using Generic Australia Pre Defined. DVB-T
I Manually Mapped The Services .
No channels were showing as no PVR Client was set up yet.
The issue was TvHeadend HTSP Client was not enabled .
I enabled it / Rebooted and all my Mapped Channels Appeared.
Your Work Is Appreciated But YOUR DRINK Link is not Visible ???
Test Results for another Box I've had for a while and NEVER been able to get any MUXES or Services with any Build.
Tried this Test Build with kszaq device tree gxl_p231_1g_dvb.dtb but failed as below.
Winsat ModelCombo Tuner AVL 6862. S905D 1gb/8gb
Same Tuner avl6862
Same S905D Chip
1gb ram / 8gb memory
Android MARSHMALLOW.
During scanning ALL muxes Failed and No services found.
afl1 what tvh version that work flawlessly with your build especially for decrypting powervu
Display Moreafl1 I don't know what you've done but i just did a FRESH Install of this Test Build on my K1 Pro and for the
FIRST Time EVER
Same Tuner avl6862
Same S905D Chip
Sorry, I am teetotaler, no beers.
In my build is the same driver as in kszaq. The issue can be only in tvheadend version.
For this test build I need feedback about channel zapping speed and quality. There is main difference.
Tvh from LE repository works flawlessly or you can test the latest 4.2 and 4.3 versions.
