  • Hi all.
    I try to install libreelec 8.0 for kI+, but can't to install tvheadend pvr client from libreelec repository.
    Client report me (the addition 5.2.0 is not found)
    Update: The client from here pvr.hts-3.4.10.zip is working fine.
    A quick feedback: The system is good, all features are working fine. Thanks for developers!
    Edited once, last by zonder33 ().
  • Hi all.
    As answered by pawnthep, you need to download pvrs-v17b6.tar, once uncompressed you will find 19 different pvr client addons in zip format. There's a link in afl1's OP. If you use Chrome, use another browser to download that file. Google Chrome masked mega.nz site.
  • [hr]
    afl1: can you pls fix the download link in the first post pls ? i cannot able to download it. giving me error to load megaupload.
    Edited once, last by plikmuny ().
  • [hr]
    After installed to Kii Pro's NAND and let it running overnight, memory management seems OK. It's still only 13%. Still not tested much though.
    As tvheadend server, I can now play live TV, both on Kii itself and on remote TVH clients, without buffering issue. So far so good. :D
    The only issue for now is that built-in bluetooth can't be used when wifi is enabled. (It works very well when I use only Lan and disable wifi.)
  • Thanks for your report. Why do you need Bluetooth when u have wifi ?
    hmm, anyway, i am right now installing this build to NAND .
    Do i have to change the Device Tree on K1+ or just prepare USB with this image and using Putty, installtointernal command is sufficient ?
    Update: its working great. only thing is i have to manually enable all the addons in th settings.
    other than that it is quite snappy and it doesnt consume much memory. i love it.
    Thanks afl1 for this wonderful build. i have it installed on NAND without any issues.
    I use bluetooth for bt headphone.
    After you successfully install to sd card (or usb) and configure everything you want to see if it works best for you, then just ssh to and use "installtointernal" command.
    I believe it's original kszaq's script. It also has option to copy userdata from sd card to NAND.
  • I tried on k2 pro and dvb-t still not working... Fail the scan (only 18 channels found), but with dvb-s it's ok
    Inviato dal mio LG-D802 utilizzando Tapatalk
  • Hi afl1 and kszaq,
    I want to thank you for your great work! The system works very smooth and stable.
    I'm using the Kii pro and installed and configured the TVHeadend-server successfuly but I'm not able to install the TVH-Client. This is also not part of the offered ZIP . Is there any other client that can be used with TVH-Server or can you recommend any other server-client combination?
    Sorry for the maybe dumb question but I'm new to all this streaming stuff.
    Tvheadend uses pvr.hts included in pvr's archive.
  • Tvheadend uses pvr.hts included in pvr's archive.
    hi afl1 will you possibly be doin a 32-bit build? I'd really like having emby running at the same time on the box so i can put it in my little girls room. Thanks
  • K1 Plus Combo
    LibreELEC-S905.aarch64-8.0-devel-20161223180220-r4-gb0d686b
    Clean install on Samsung 32GB EVO+, TVHeadEnd from repo 8.0.107, TVH client provided here: pvr.hts-3.4.10
    Works fine for few minutes, then picture stops and:
    kodi.log repetitive entries
    libamcodec.so found here: /usr/lib/libamcodec.so
    EDIT:
    ok, seems like the core problem is not related to the log entries, but rather the TVH server not providing data or other instability.
    Edited once, last by Ftelf ().
  • Update in first post. In new version I fixed RC extra buttons (color buttons, start, stop, EPG, Info, Subt,.. ). I cannot find right code for Audio button as 'next audio track'. Currently is used for audio offset. I'll welcome any suggestion for buttons interpretation in kodi. I also used latest kszaq kernel to improve playback and stability. I am still building 64-bit version as I am not able to compile kszaq 32bit Krypton version.
  • Hi afl1, PLZ build a new 32bit image. We love your contribution. I am managing to run kszaq 32bit build without any problems and with stability on k1 plus.
    Waiting for your reply and help
