@kszaq I've run into a little problem with these builds and the MAC address of the devices.
All OE builds before 6.0.1.2 change MAC address every reboot and all others OE / LE are giving me the same MAC address (00:01:23:CD:EE:AF) for two different devices. In android the two different devices correctly show different MAC addresses.
I have tried all the different MXQ builds using the update files and the install (zip) method with the same result.
For now, to avoid IP clashes on my LAN, I am assigning static IP's to these devices but, wonder if it will lead to issues down the track.
This is only an issue with the 3_1 type boards, I also have a 2.0 board which shows a different MAC address to the others, as it should
Has anyone else reported anything similar?
