Tested it again. If 280-350MB is too much, you can tell me.
Upload should be finished the next 20 minutes. I will put a log in the folder too (MEGA-Folder,check PMcan't send you PMs )Here is the folder, tell me if I can delete it.
MEGAit is freezing after 4sec everytime.
Edit:
Just tested another movie ... Same thing. But I think I was able to watch HVEC already. At least I tested to play it, somewhere before .008.
Thank for the sample, downloaded. I will post an update when I have something to test.
First suggestion: try using echo 16 > /sys/module/amvdec_h265/parameters/dynamic_buf_num_margin
