LibreELEC 9.0.1 builds for S905 (semi official)
  • Detalhes
    I mean your Tvheadend configuration is wrong. This is not related to Libre/Coreelec. You should check your Tvheadend to solve that
    I want to say there is nothing wrong
    the settings are correct
    time works time does not work
    and need a restart.
    CvH
    Edited once, last by erbas ().
  • Apparently, there is something wrong. Message is self explaining.
  • I guess you adjusted the wrong thing at the resolution white list ?
    I selected all 3840 resolutions on the whitelist, rebooted, still only 1080p. Switched to Coreelec and 4k works out of the box
  • LibreELEC 9 Beta 3 was released
    It's working 20 hours ago on tvheadend
    DVB-S Satellite.
    if you fail without problems!
    But I can only report what is good because
    As I said before my and just to see Tv.
    The problem with Tvheadend HTSP Client does not appear as before. After restarting dozens of times it was only seen a single time,
    "Tvheadend HTSP Client - No free adapter available":idea:
    CvH Can we expect the same work with support for LE9.2 / LE10, replacing dtb with the correct gxl_p230_k1_pro.dtb:?:
    KI Pro (S905D)
    Great job!:thumbup:
  • Can we expect the same work with support for LE9.2 / LE10
    for LE9.2/LE10 there are complete new drivers - thats why we didn't waste our time in improving the current (very old and not that good) driversd
    I can't really predict what to expect yet.
    Is there any specific improvement for S905?
    nope, just what came down from Kodi and overall LE improvements
  • for LE9.2/LE10 there are complete new drivers - thats why we didn't waste our time in improving the current (very old and not that good) driversd
    will older devices like the wetek play 2 still be supported?
  • What would the changes of this working on an s905x be? Currently running the kszaq libreelec 8.2 build installed to internal.
