Hm ok, I might test but my NUC7i5BNK is Gen7, no? Still worth a try even Intel mentions only Gen9?
						Gedeon30
					November 23, 2018 at 7:33 PM
							Closed
													Thread is Resolved
			Hm ok, I might test but my NUC7i5BNK is Gen7, no? Still worth a try even Intel mentions only Gen9? GPU generation is what's important here. Kaby Lake = Gen9 GPU.
			Oh great, me noob, thanks for clarifying!
			No go for me
 Made sure prime hw decode was on (can see it’s using ff-hevc-drm_prime(HW)).
 Anyway, all I get is blank screen. Can see it’s playing though. No hdr switch not that it would help with no video Something is going funny with audio too as it isn’t picking up any device and is greyed out on Bluetooth, that may or may not be related.
 For the record this is clean install on an empty m2 so happy to try again in the future if needs be.
 Tv is Samsung UE40MU6400
 I can get you logs if you think it would help, but I’m by no means expecting you to support anything, just trying to help out test, which I feel may be a little too early to do yet.
			Same for me sadly on the NUC7i5BNK. Logs is like this: Code
 Display More2020-04-24 20:39:20.535 T:1161 ERROR <general>: Open - Error, could not open file smb://ben/mass3/mymovie.mkv 2020-04-24 20:39:20.535 T:1161 ERROR <general>: ExtractThumb - Error creating demuxer 2020-04-24 20:39:20.665 T:1161 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding) 2020-04-24 20:39:21.047 T:1161 INFO <general>: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding) 2020-04-24 20:39:21.341 T:757 INFO <general>: VideoPlayer::OpenFile: smb://ben/mass3/mymovie.mkv 2020-04-24 20:39:21.342 T:1219 INFO <general>: Creating InputStream 2020-04-24 20:39:21.353 T:1219 INFO <general>: Creating Demuxer 2020-04-24 20:39:21.500 T:1219 INFO <general>: Opening stream: 0 source: 256 2020-04-24 20:39:21.500 T:1219 INFO <general>: Creating video codec with codec id: 173 2020-04-24 20:39:21.500 T:1219 INFO <general>: CDVDVideoCodecDRMPRIME::Open - using decoder HEVC (High Efficiency Video Coding) 2020-04-24 20:39:21.502 T:1219 INFO <general>: Creating video thread 2020-04-24 20:39:21.502 T:1225 INFO <general>: running thread: video_thread 2020-04-24 20:39:21.502 T:1219 INFO <general>: Opening stream: 1 source: 256 2020-04-24 20:39:21.502 T:1219 INFO <general>: Finding audio codec for: 86020 2020-04-24 20:39:21.503 T:1219 INFO <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder dca 2020-04-24 20:39:21.503 T:1219 INFO <general>: Creating audio thread 2020-04-24 20:39:21.503 T:1226 INFO <general>: running thread: CVideoPlayerAudio::Process() 2020-04-24 20:39:21.503 T:1219 INFO <general>: Opening stream: 3 source: 256 2020-04-24 20:39:21.504 T:1225 INFO <general>: CVideoPlayerVideo - Stillframe left, switching to normal playback 2020-04-24 20:39:21.513 T:1226 INFO <general>: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through) 2020-04-24 20:39:21.603 T:764 INFO <general>: CActiveAESink::OpenSink - initialize sink 2020-04-24 20:39:21.687 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.162 T:764 INFO <general>: PulseAudio: Opened device Default in pcm mode with Buffersize 300 ms Periodsize 100 ms 2020-04-24 20:39:22.199 T:757 INFO <general>: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY 2020-04-24 20:39:22.443 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.477 T:764 ERROR <general>: Sink Timer expired for more than buffer time: 300l 2020-04-24 20:39:22.484 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.526 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.568 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.610 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.651 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.693 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.735 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.776 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.818 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.860 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.901 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.943 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:22.985 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.027 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.068 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.110 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.152 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.193 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.235 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.277 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.319 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.360 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22 2020-04-24 20:39:23.402 T:757 ERROR <general>: CVideoLayerBridgeDRMPRIME::Map - failed to add fb 0, ret = -22Tried "Direct-To-Plane" and "EGL" in the PRIME settings.
			I'll write this image to my NUC this weekend and give it a spin and report back.
			So I get no audio on boot. Is there a reason you decided to go with PulseAudio instead of the stock ALSA like vanilla LibreELEC? Just like PlatypusW pointed out you just get a greyed out choice in Settings -> System -> Audio that says PulseAudio Bluetooth. I do see that by default all my HW acceleration is enabled including Prime. I will attempt a video test but I can't guarantee a failed video is actually legit failed as i've had this issue on other builds that use Pulse that if the audio isn't working properly, video will not work properly. EDIT: Yup, I get nothing when I try to play a video, but I don't consider this a failed test yet as I had similar issues play ANY content in RetroELEC that also uses PulseAudio instead of ALSA. I adjusted the kodi in it to use ALSA and video playback started working properly. EDIT2: d9e85 - Ghostbin
			I didn't do anything to the audio part, ALSA works fine on my Gemini Lake box. Maybe it has something to do with this.
			It ist a bug which affects the NUCs You can Turn Off HD Audio in BIOS Or Blacklist the DSP...
			i ordered a NUC8 i3 but cancelled after seeing this thread good to see progress on LSPCON HDR but wont buy until its working as my NUC6 works fine just does not do HDR
			Audio works perfectly after the disabled HD Audio DSP in bios. Excellent. Unfortunately no video while playing a 4k HDR flick. I can hear audio, AVR displays Dolby Atmos properly, but only get black screen. Hitting 'o' pulls up the stream info and decoder is set to prime. Once again, this is on a i3 8th gen NUC
			So were these patches suppose to enable Kaby lake or coffee lake? Or was it Gen9 graphics which technically is everything from Skylake to coffee Lake i believe. According to this wiki, the Iris Plus 655 which my 8th Gen i3 NUC has is listed as a Gen9 unit.
			4K 4:2:0 with Deep color is not a part of HDMI spec. It should always be 8-bit. No idea how to force YCbCr 4:4:4. Intel driver knows what's best for you and use RGB. That's not correct, if by Deep Color you mean >8-bit bit depth. In fact it's quite the opposite. 4:2:0 is supported in 8, 10, 12 and 16-bin 2160p50/60 modes - it's the only sub-sampling format supported in all bit-depth outputs for 2160p50/60 modes. 4:2:0 was added to HDMI 2.0 - and is only supported for 2160p50/60 modes, with no support in 2160p24-30. RGB/4:4:4 are only supported in 8-bit at 2160p50/60 - so whilst you may be able to flag an HDR EOTF with 2160p50/60 RGB/4:4:4 output - you can't output 10-bit sources in 10-bit or 12-bit in an RGB or 4:4:4 mode with a 2160p50/60 output format. (RGB/4:4:4 is only an option for HDR at 2160p24-30) 4:2:2 is the only >8 bit format supported for all 2160p frame rates - from 24p-60p. It is supported with 12-bit bit depth only. (So 8-bit SDR and 10-bit SDR or HDR (*) video is padded - there are no 8-bit, 10-bit or 16-bit onions for 4:2:2 output at any frame rate in the spec) 4:2:2 is thus the ideal preferred mode for 2160p HDR output - as it is supported at all frame rates. (This is why it is used by a lot of consumer products) 4:2:0 is the second best option for 2160p HDR output at 2160p50/60 - but can't be used for 2160p24-30. 4:4:4/RGB is only an option for 2160p HDR in 2160p24-30 modes. Therefore if you can't use 4:2:2 for HDR output of 10-bit HDR material properly (i.e. without truncating to 8-bit) you have to use RGB/4:4:4 output for 2160p24-30, and 4:2:0 output for 2160p50/60. The only format supported in all frame rates is 4:2:2 See attached HDMI 2.0 timings chart downloaded from the HDMI site. HDMI 2.0b or HDMI 2.1 may have added >8-bit depth support for RGB/4:4:4 in 2160p50/60 modes - but it certainly wasn't supported in HDMI 2.0 (or 2.0a AFAIK) (*) I watch quite a lot of self-mastered HD SDR 10-bit content - it looks so much nicer than 8-bit content covered in quantisation banding
			That's not correct, if by Deep Color you mean >8-bit bit depth. In fact it's quite the opposite. I thought that was clarified back in February, not sure why you have to bring that up again. 4:2:2 is the only >8 bit format supported for all 2160p frame rates 4:2:2 is also irrelevant for any Intel hardware, not supported by the driver.
			I thought that was clarified back in February, not sure why you have to bring that up again. 4:2:2 is also irrelevant for any Intel hardware, not supported by the driver. Apologies - I hadn't remembered I'd previously posted that information in the same forum. So do Intel just support 4:2:0, 4:4:4 and RGB output? If so then 4:2:0 is the only format that will support 2160p50/60 with >8-bit for HDR - unless you are in the realms of HDMI 2.1 (or was >8 bit RGB/4:4:4 added in HDMI 2.0b for 2160p50 and above)?
			So do Intel just support 4:2:0, 4:4:4 and RGB output? Yes. If so then 4:2:0 is the only format that will support 2160p50/60 with >8-bit for HDR Yes. but the driver default to RGB 8-bit. A driver hack is required in order to switch to 2160p50/60 4:2:0 12-bit. AMD behave a bit different - no 4:2:2 support either but the driver default to 4:2:0 12-bit for 2160p50/60 modes.
			Yes. Yes. but the driver default to RGB 8-bit. A driver hack is required in order to switch to 2160p50/60 4:2:0 12-bit. AMD behave a bit different - no 4:2:2 support either but the driver default to 4:2:0 12-bit for 2160p50/60 modes. Great - so the industry standard for video production and post-production (4:2:2) - and the standard for connectivity in that area - is the one format that isn't supported...
			Great - so the industry standard for video production and post-production (4:2:2) - and the standard for connectivity in that area - is the one format that isn't supported... They actually planned to support 4:2:2 as seen in this old patch but then it was dropped for some reason. I tried to enable 4:2:2 support in driver but it didn't work, I guess I missed something.
