  • Current HDR support starts at 9th Gen (Gemini) and based on Q&A with Intel devs a couple of days ago Intel has no current plans to implement HDR for older Generations. We might try to influence that once Kodi support has matured, but I wouldn't get hopes up.
  • Thank you very much!
    So, on the NUC7PJYH the HDR works but I have problems with DTS-HD audio (sometimes I hear some annoying clicks from the speakers and I must be honest, they also scared me) while unfortunately on the other NUC NUC10i7FNH the HDR does not work.
    I dont have that issue iam using DTS HD and HDR. Maybe its your HDMI cable that is bad. Iam using HDMI 1 for Video HDR and HDMI 2 for DTS-HD audio
  • I must say this is like a dream come true for me . I can confirm this build work for me on my NUC7PJYH with ny LG OLED C8 55 inch and now i have HDR and 7.1 . No more need to get a Nvidia Shield . Thank you very much to making this true. But i have a question how do i get my vfs unrar back? Who made this build i want test more if needed ?
    Still no HDR on my NUC7i3BNH box.
    Is this because NUC7i3BNH (Baby Canyon) had the LSPCON in it while the NUC7PJYH (June Canyon) didn't?
    Got to love intel .. your "higher" end i-core product doesn't work but your celeron/pentium does from the same time period.
    NUC7PJYH is not official supported by Intel with HDR but it still work with smp build for me to get HDR.
    Their stuff is so confusing .. "9th Gen (Gemini)" yet it comes in a 7th gen labeled NUC .......
  • Gemini is actually "Gen 9.5". It has Gen 10 display block, that's why we have a working HDR on those SoCs.
    Btw, their next generation low power SoC (Tremont/Jasper Lake/Elkhart Lake) is inferior as far as video playback is concerned. It does not support high quality deinterlacing (MADI, MCDI) and it can only do BOB DI.
    Tiger Lake SoC looks awesome (Gen12 GPU, can do AV1 in hardware) but it's expensive.
    Edited once, last by smp ().
    So Gemini (J4005 & J5005) are Gen 9.5 and work
    Bean Canyon "8th gen" labeled NUC's that have i3/i5/i7 are Gen 9 and currently don't work but per what chewitt said above might in time? (even though Gemini are labeled 7th gen NUC) .. SO CONFUSING
  • I can access the files on my PC via UPNP, seem to work fine here.
    Which version ? LibreELEC-GBM.x86_64-9.80-devel-20201121180445-3325d42.img.gz or LibreELEC-GBM.x86_64-9.80-devel-20201127171518-1e75df4.img.gz
  • PlatypusW
    pletopia
    Snoopy
    I compiled a build with new LSPCON patches and new Kodi drmprime stuff from lrusak's branch. Maybe worth a try.
    https://www.dropbox.com/s/n7a5…71518-1e75df4.img.gz?dl=1
    Thank you very much! :) works great with local hdr content on my NNUC7PJYH2
    Should I use "direct to plane" or "EGL" as rendering method? And does anyone have tested Netflix with this build yet? It does not work for me. As soon as the playback starts, the screen gets darker shortly, but then get stuck. Audio playback works fine.
  • Excuse me if I'm self quote but I don't think smp read my post.
