1. Forum
    1. Unresolved Threads
  2. Blog
  3. About
  4. Downloads
  5. Contribute
  6. Sponsor
  7. Wiki
  8. Issues
  • English
  • Login
  • Register
  • Search
This Thread
  1. LibreELEC Forum
  2. HELP & SUPPORT
  3. Add-on Support
Netflix
  • mihailstacanov
  • September 8, 2018 at 11:21 AM
  • Thread is Unresolved
  • 1
  • 2
  • 3
  • 4
  • chris256
    Beginner
    Posts 25
    • March 10, 2019 at 8:35 PM
    • #37
    Hello everyone !
    I tried to install the Netflix plugin by doing what follows :
    1. Add the Netflix Addon repository
    2. Install the Netflix plugin with dependencies
    3. Install the latest inputstream addon
    When I launch the Netflix Extension, I enter my email and Netflix password but then I have an error that it cannot log in (I am 100% sure that my login informations are correct).
    I am on X86_64. Can anyone help ?
    Thanks !!!
  • spiderfish
    Student
    Posts 138
    • March 12, 2019 at 12:06 PM
    • #38
    Quote from chris256
    Hello everyone !
    Thanks !!!
    Display More
    Provide more about the error message what is it and put your logs to be able to help you
  • stark
    Beginner
    Posts 1
    • March 14, 2019 at 9:20 PM
    • #39
    Quote from chris256
    Hello everyone !
    Thanks !!!
    Display More
    Have a look here.
    Maybe you could try to enter your login info by getting into the add-on settings and see if it works
    Netflix Add-on [input-stream]
    Edited once, last by stark (March 15, 2019 at 4:04 AM).
  • chris256
    Beginner
    Posts 25
    • March 17, 2019 at 10:46 AM
    • #40
    Quote from stark
    Have a look here.
    Thanks ! That worked. At first launch if I enter login information that does not work but if I go into settings, set the login information then launch, it works. Thanks also spiderfish for your reply.
    It does not matter but just to let you know that the login name is not displayed in settings, probably a small bug.
    Have a nice day and congratulations to the developpers !
  • spiderfish
    Student
    Posts 138
    • March 18, 2019 at 3:58 PM
    • #41
    chris256
    Great that is worked :)
  • optimizer
    Beginner
    Posts 2
    • March 18, 2019 at 6:02 PM
    • #42
    Okay i cant seem to get this to work propertly.
    1. I have a raspberry 2 with the latest libreelec build 18.1 leia.
    2. I have downloaded the latest netflix plugin 0.14.0-BETA23
    3. Ive installed the plugin and enabled inputstream v.2.3.15.0
    4. I have entered my login details and are able to login and view every netflix library
    This is where it gets tricky...
    5. When I select a movie to watch it popups (like it should) "Widivine CDMs required" so i press "install Widevine". Another popup about Widevine popups and i press "YES" followed by "Widevine CDM EULA" which i press "I accept" on.
    6. Then it starts to download the "chrome OS recovery image" which takes some time..when its finally done it fails the playback so i reboot and return to step 5.
    Now im in a loop allover again with the Widevine and I cant seem to get around it. Any suggestions?
  • optimizer
    Beginner
    Posts 2
    • March 19, 2019 at 7:53 PM
    • #43
    Quote from optimizer
    Display More
    i do get it to work on my desktop htpc, but cant figure out how to get that Widevine CDM to work on my rasp with libreelec..any tips?
    Edited once, last by optimizer: OK! Got to work, was the unpacking of the file taking alot of time! (March 19, 2019 at 8:31 PM).
  • ryangodammit
    Beginner
    Posts 10
    • May 26, 2019 at 4:41 AM
    • #44
    Has anyone got Netflix working on libreelec at the moment?
    It used to work fine for me but I haven’t been able to find a working configuration for ages.
    I’m running libreelec 9.0.2 on an asus chromebox and am trying all manner of different Netflix builds but nothing is working.
    Anyone know?
  • backslash
    Student
    Posts 74
    • May 26, 2019 at 8:46 AM
    • #45
    Quote from ryangodammit
    Anyone know?
    The version from this repository is the most current one and works for me without any issues: repository.castagnait-1.0.0.zip
  • frequenzy
    Intermediate
    Posts 217
    • May 30, 2019 at 5:37 AM
    • #46
    may I know what widevine version should I manually download for s905x? when using the automated, it can't fully download so I'm looking to download widevine first on a pc.
    widevinecdm.json
  • xav42
    Beginner
    Posts 1
    • August 14, 2019 at 9:04 AM
    • #47
    Hi everyone,
    I have a Rpi 2 model B, I just installed Libreelec 9.1.
    And I added the netflix plugin.
    I entered my email address, my password. I now can see the users, and for each of them the latest programs seen, the selection,..
    But when I launched a program, I'm asked to install widevine, I accept and it fails quite quickly.
    I'm trying since yesterday. The first times I had to accept the EULA, but now I don't reach this step.
    The kodi.log file is in attachment.
    I have downloaded manually the 2 files that seem to be the problem:
    recovery.conf
    1.4.9.1088-mac-x64.zip
    and I got them without worry. So I don't understand why the plugin can't find them.
    Does someone knows what I could do to solve my problem?
    Best regards.
    Edit : in fact it seemed I had a not reliable internet connection, so the download was probably interrupted each time I tried to get the widevine.
    I tried again, and it worked. Everything's fine now, thanks a lot for all the solutions on this forum.
    Files
    kodi.log 37.5 kB – 621 Downloads
    Edited once, last by xav42: Solved problem (August 14, 2019 at 1:06 PM).
  • milo
    Student
    Posts 60
    • April 1, 2020 at 9:38 PM
    • #48
    Hello, i cannot log me in.....it always says incorrect password but it is the right password....what's wrong?
  • esajosi
    Beginner
    Posts 2
    • April 2, 2020 at 8:59 PM
    • #49
    Hello,
    I am using RPI3 with LibreELEC 9.2.1 and KODI 18 (Leia).
    Installed Netflix addon and worki9ng a lot on it to get it working.
    It began play a film once, but after a restart it shows a film starting forever...just a rotating dial.
    the dmesg output:
    http://ix.io/2goA
    the kodi.log:
    http://ix.io/2goD
    Can you give mi any hint on the problem?
    THank you!
    Ervin
  • Shienor
    Beginner
    Posts 12
    • April 15, 2020 at 6:03 PM
    • #50
    Quote from milo
    Hello milo,
    have you used a addon on our Smartphone for the password?
    When yes, use a keyboard.
  • milo
    Student
    Posts 60
    • April 29, 2020 at 8:12 AM
    • #51
    I used a keyboard but still the same error
  • crespo
    Beginner
    Posts 6
    • May 4, 2020 at 3:37 AM
    • #52
    Hi, I'm getting stuck after uncompressing widevine cdm. I get this error:
    2020-05-03 22:48:23.808 T:1410708352   ERROR: [plugin.video.netflix (1)] Traceback (most recent call last):
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/run_addon.py", line 182, in run
                                                    route([part for part in g.PATH.split('/') if part])
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/run_addon.py", line 33, in lazy_login_wrapper
                                                    return func(*args, **kwargs)
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/run_addon.py", line 57, in route
                                                    play(videoid=pathitems[1:])
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/common/videoid.py", line 294, in wrapper
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/common/logging.py", line 133, in timing_wrapper
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/navigation/player.py", line 72, in play
                                                    list_item = get_inputstream_listitem(videoid)
                                                  File "/storage/.kodi/addons/plugin.video.netflix/resources/lib/navigation/player.py", line 144, in get_inputstre
    am_listitem
                                                    if not is_helper.check_inputstream():
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 407, in che
    ck_inputstream
                                                    return self._check_drm()
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 362, in _ch
    eck_drm
                                                    return self.install_widevine()
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 33, in clea
    n_before_after
                                                    result = func(self, *args, **kwargs)
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/__init__.py", line 223, in ins
    tall_widevine
                                                    result = install_widevine_arm(backup_path())
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/widevine/arm.py", line 240, in
                                                    extract_widevine_from_img(os.path.join(backup_path, arm_device['version']))
                                                  File "/storage/.kodi/addons/script.module.inputstreamhelper/lib/inputstreamhelper/widevine/arm.py", line 253, in
                                                    for root, _, files in os.walk(mnt_path()):
                                                  File "/usr/lib/python2.7/os.py", line 296, in walk
                                                  File "/usr/lib/python2.7/os.py", line 286, in walk
                                                  File "/usr/lib/python2.7/posixpath.py", line 73, in join
                                                UnicodeDecodeError: 'ascii' codec can't decode byte 0xc5 in position 29: ordinal not in range(128)
    Display More
    LE 9.2.1 (from scratch)
    Netflix 1.2.0
    InputStream Adaptive 2.4.4.1
    RTMP Input 2.0.9.1
    By the way, great distro ! Congrats!
    Edited once, last by crespo (May 4, 2020 at 3:55 AM).
  • esajosi
    Beginner
    Posts 2
    • May 4, 2020 at 10:43 PM
    • #53
    maybe someone can use it: i found the solution for the RPI3: I had to limit the resolution to Full HD 1080p and it runs smoothly.
  • crespo
    Beginner
    Posts 6
    • May 4, 2020 at 11:36 PM
    • #54
    Quote from esajosi
    maybe someone can use it: i found the solution for the RPI3: I had to limit the resolution to Full HD 1080p and it runs smoothly.And
    I will try it once I get Netflix plugin to run ^^
    • 1
    • 2
    • 3
    • 4
Similar Threads
  • [8.2.4.1] LibreELEC Kodi Krypton - S905 & S912 devices
    • wrxtasy
    • April 24, 2018 at 3:16 AM
    • Amlogic
  • Will there ever be a working Netflix Addon for RasPi?
    • novalis
    • September 1, 2018 at 9:55 AM
    • Add-on Support
  1. Privacy Policy
  2. Cookie Policy
  3. Contact
Powered by WoltLab Suite™
  • Everywhere
  • This Thread
  • This Forum
  • Forum
  • Pages
  • More Options
  • Deutsch
  • English
Save Quote
