Hi Balbes, Please assist every time that tried to write into emmc fails
Display MoreHi Balbes,
I current have this version LibreELEC-S905_SD_USB.aarch64-17.6_20180122.img working in my Tronsmart s905 emmc.
Also I have burned this version LibreELEC-S905.aarch64-9.0-devel-20181114151758-cbfbde4.img into SD card and is working fine, each time I tried to write this version in emmc I get an error message.
The process will start with write to emmc, after a short time the box will power off.
Next I removed the SD and power on the box, then a script message pop up
"Never touch boot=in ex linux.conf /cmdline.txt!
if you don't know what you are doing,
your installation is now broken.
normal startup in 60s....20"
after the above several lines of scripts is written
"FAILED] failed to start load kernel models"
Could you advice where I have gone wrong, How to update S905.aarch64-9.0 into existing emmc S905_SD_USB.aarch64-17.6.
