  • I installed GT KING PRO and it opens but the interface turns green.
    I set up both images, both are the same.
    LibreELEC-ARM-ALL.arm-9.80-devel-20200214123317-569f834-amlg12.img.gz
    LibreELEC-ARM-ALL.aarch64-9.80-devel-20200214124241-569f834-amlg12.img.gz
  • The image is not bootable.
    Read the first message of the topic.
    2. Cryptodome library missing in the build so addons that rely on cryptodome refuse to start
    3. inputstream.ffmpegdirect is missing in the build
    Describe in detail the steps for checking what I can check for myself.
    eMMC fitur : Install to eMMC not working
    i try with tar file, not compatible file
    TV box model, the exact name of the files used. And a full description of all the steps.
  • Good balbes150 , I had recently updated my android, so it was necessary to install universal multi-boot again, something I had done almost 2 years ago.
    Thank you I leave the link here, in case someone else has the same problem.
    update_uboot — Yandex.Disk
    s905_multi_boot · 150balbes/Amlogic_s905 Wiki · GitHub
    After that, everything went well! as expected.
    Some important addons like pvr.hts, crazycat are missing.
    CvH please how is the TBS5520SE driver process going?
    Bring some news to minimize expectations.:idea:
  • Good to hear that someone is working on the driver
    TBS5520SE Because I am dependent on the same in my rasp and in my box tv.
    I would also like to know if we will have it up and running soon!
    Thank you for reporting this work we will support.
    crazycat, CvH we will support.
  • Thank you Erbas for this information.
    Everything is very clear in the first post!
    balbes150 edited the first post and made it very clear, for possible problems.
    In the case of your problem. Fix for correct color to G12 :thumbup:
    For models based on g12 (s905x2 s922), which have a problem not the correct color, to SD card to write the image and rename u-boot.sd to u-boot.ext, to USB to write the image and rename u- boot.usb to u-boot.ext
  • Quote from gujal
    balbes150 Just install Netflix plugin from the offical netflix repo
    https://github.com/CastagnaIT/plugin.video.netflix
    Dont even have to configure it as it runs a service which relies on Cryptodome part of script.module.pycryptodome
    I then checked the /usr/lib/python3.7/site-packages folder and both Cryptodome and PIL are missing, so both script.module.pycryptodome and script.module.pil are broken in the current build
    This is the content from milhouse R-Pi build of the same directory and you can see that it has both cryptodome and pil
    Regarding inputstream.ffmpegdirect, this is quite new and milhouse has it included in his recent builds since #213, may be it is too early to be in your build
    Edited 6 times, last by gujal (February 17, 2020 at 11:47 AM).
