Thanks ! But, How to do ?
Read first post in:
Read first post in:
Read first post in:
Thank you very much,
I tried with "gxm_q200_2g.dtb" and "gxm_q201_2g.dtb", but, same problem.
I followed "if booting from SD/USB, simply connect SD/USB to your computer, download a proper device tree, rename it to dtb.img and place on SD/USB"
Are you sure you used the LibreELEC-S912.arm-8.90.6.tar and not the S905 when you updated?
I used : "LibreELEC-S912.arm-8.90.6.img.gz" ; With : "LibreELEC.USB-SD.Creator.Win32" ; With "gxm_q200_2g.dtb"
Just did a clean install on a Nexbox A95X. And every thing works just fine
Et vous avez renommé ce fichier en "dtb.img"?
Paul
Yes.
Les
In my opinion, there is a bug with the Amlogic S912.
Yes.
After burning the new img.gz file to the sd card. There should be a folder on the sd card named devicetrees.
Delete the dtb.img on the root folder of the sd card, and copy the right dtb file from devicetrees to the root folder and rename it dtb.img
see if this works.
Les
Or maybe you don't have 2gig ram. You may have one with facke ram, so you could try the 1gig tree.
Have you been able to get the original remote to work in mouse mode? I have been unable to get it to work in mouse mode ever since the changeover to the LE driver instead of the Amlogic driver. Other than that, the new version is very good, smooth and fast.
I don't use original remotes
Les
see if this works.
Thanks ! But, Always the same...
No, the beelink GT1 has 2GB.
Too bad, I give up.
No mouse mode here either.
Je viens d'essayer la même manipulation avec 90.5 et ça marche. Donc, ce 90.6 est faux / buggy. Pitié ! Je vais attendre 9.07.
Good Sunday !
I mentioned this in the other thread before it was closed but has anyone else experienced the picture shifting a pixel or so left and right constantly with 8.90.6? It's really noticeable on any video with static vertical lines. I thought it was just with DVB stuff but I've noticed it on other videos too now.
Just did some more test's and both my Nexbox and MeCool have no such shifting. Dose it stop when you pause the video?
