Does this dvb s2 tuner work?
  • still doesn't work i guess ?
    btw did you tried the LE image ? btw I would try something - maybe helps
    what platform do you need ?
  • CvH You are right. Still not working.
    I tried it on an normal x64-machine with kernel 4.17.4. LE should only bei the slave system with the tvheadend client.
    I could also be a problem with USB 3.0.
    How i can test your work?
  • Terratec Cinergy S2 USB Box from 2018 is also not working due B chip. Looks like there is no working usb DVB-S2 device for linux anymore.
  • CvH and @Softlander
    Btw.: happy new year !
    moons ago I made entries under the bold word "Update" regarding linux support for
    TerraTec Cinergy S2:
    https://www.linuxtv.org/wiki/index.php/terratec_cinergy_s2_r2#update
    and
    TechnoTrend TT-connect S2-4600:
    https://www.linuxtv.org/wiki/index.php/technotrend_tt-connect_s2-4600#update
    to prevent other user from buying unsupported/painfull hardware/seller.
    Question(s):
    Are my statements under the above links still valid or should I remove them ???
    @Softlander
    from your log in #138 I can't fetch that your usb-tv-stick *is* running, it's waiting for firmware upload...:cool:
    So my special questions to you are:
    Did your device ever finished uploading the firmware !
    or even better
    Are you ever able to watch TV on it (without driver bugs/hickup's, etc) ?
    P.S.
    I'm not completely sure, but I guess everyone should be able to change/remove my entries in the above links at LinuxTVWiki if you feel so or if my statements there currently became invalid.
    I especially stress the last sentence cause I'm not really often come around this thread any more - is this a correct english wording ? - after switching to an Sat-IP-Server.
    Anyhow wiki entries should be correct !
    comments/thoughts/rotten fruits
    (salutation speech pirated from kernel.org ML's) :saint:
    DigiBit R1, NUC8i3BEH
