How to Enable Bluetooth
  • Hi All.
    I am very new to this and I want to pair my Bluetooth speakers to my RPI3 running LibreElec any help will be highly appreciated
    I know the Bluetooth on my RPI and my speakers are working as I can pair the RPI and the speakers in Rasbian and play music from the web browers (example an internet radio)
    I go in libreElect Settings Bluetooth and it always show Bluetooth disabled ,I have looked in all settings possible but no where do I see something that enables Bluetooth.
    If someone will help me with a description or instruction where to find this I will be grateful
    Thank you very much
    QMESAR
  • I change default skin to Confluence, precisely cause in default skin "LE Settings" didn't appear. I'll see under "add-ons" like you told me.
    Thank you
    Update: Effectively, there are an addon called "LibreElec Settings" and now I can enable Bluetooth. ;)
  • This works fine
    But is it possible for it to drop back to a default source when the Bluetooth one can't be found?
    Be nice if I could turn the speaker on to listen to music, but when I turned it off it just dropped back to SDIF/HDMI for tv.
