- kszaq
- Thread is Unresolved
8.2 working just fine on x96 xgoody box, network fine, playback just fine,
Used the correct dtb file and it failed to boot after update, booted from usb and used the SSH commands with the same dtb then it booted fine from internal.
Previous versions was 8.0.2e.
Just applied this update. No obvious issues on any of the boxes so far
I just also upgraded from 8.0.2e in an s905x box, no problems. But i noticed before upgrading the libreelec menu>system is not displaying anything there is an error in the debug log for this. After the upgrade is not working either. Shall i create a new thread for this ?
edit: no problem, it was a custom update channel entry, after deleting the xml settings, the menu came back.
The CEC adapter doesn't turn on the Odroid C2 when I turn ON my TV
- removed amvideocap and stmmac kmsg spam
Will test it later. Hope this will solve the hyperion bug
Hi Kszaq: from custom update channel your recent builds are not visible. soon after entering the address and refreshing brings the blank screen. and there is no way to see the option and finally update !
can you have a look at it and if possible rectify it.
Thanks in advance for your wonderful work.
I don't provide any custom update channel, you have to ask channel provider.
Hi Kszaq, and all
i've noticed with latest 8.1.0 on S905 mini-mx 1GB that even when cpu cores are idling or <10-15% I get 75/80 C of temperature readings.
It gets really hot.
is it normal?
thanks for your work.
Plays x265 (Hi10) video that was never playable for me before without massive stuttering just fine. Seems a bit faster in the menus too.
But with this kernel, it somehow still does not play pseudo's encodes. I can't seem to find any causal link as to why, but 8.0.2e plays it, while this build only plays the very first video frame while the audio keeps playing as usual. Upon seeking in the video, still only shows that very first frame, but audio cuts out. This is all 720p x265 encoded content, and IIRC, only 8-bit.
It's a shame. I'm really liking a lot of the improvements, but I'm reverting until this is fixed.As always, thanks for your time and effort.
There's a new way of setting it, but it's broken in the current build (and I broke it). Once kszaq reverts aml/video_dev: updates for nougat: · kszaq/[email protected] · GitHub for the next build, you'll be able to run the following for forcing RGB out:
echo 'rgb,8bit' > /sys/class/amhdmitx/amhdmitx0/attr
If you don't have anything in autostart.sh yet, you'll be able to run the following to set it on boot:
echo "echo 'rgb,8bit' > /sys/class/amhdmitx/amhdmitx0/attr" > autostart.sh
That's still not working in the new build, if I'm not mistaken
It should work in 8.1.1, commit has been reverted as advised by johngalt.
What is "pseudo's encodes"? Let me repeat 100th time: any video playback issue has to be backed by a sample.
It gets really hot.
is it normal?
It's normal if your box has bad cooling. This is unfortunately common with cheap boxes.
i quickly tried dragon ball 99 pseudo and it works ok
Hi, updated my S905X to the version from July 23rd, but the "pink bug" is still there.
Try Gintama then. Any episode.
