Thank you very much. You are a kind soul.
How to connect a Xiaomi bluetooth remote control
ashrafhumax -
June 17, 2017 at 2:58 PM -
As wrxtasy got now all buttons of those aftermarket Xiaomi Bluetooth working (Thanx a lot for that again
) I would like to solve one remaining thing which is not clear to me. Hope someone here can help out.
Using that remote on the Wetek Hub with the Android TV ROM, I can perfectly power it off and start it booting from the remote. What is the missing peace in Libreelec to make this work at least on the devices supporting this, like the Wetek Hub or Wetek play 2?
Shouldn't make a difference as far as I understood, the code in uboot is interpreting the infrared signal from the remote and boots up the Wetek, that shouldn't have had changed by using Libreelec?
If someone could bring some light to this topic to me it would be really great
Thanks so much for your support here
It is really a great community!
Vlaves
Guys sorry to bring up such an old topic, but i bought one of these of ebay, ended up with something that is definatly fake, it doesnt even show up in the bluetooth settings, ive been holding home and back, just wanted to know if thats the correct procdure
also to those who ordered this one:
is it a legit one like the images or a fake one? and did it work as i might order from there
thanks
thanks
The is the correct remote. You are using the wrong buttons to pair. Use the two outside buttons, the home and *info* (three horizontal lines) buttons....... Hold for about 5 seconds while close to your box, then release. You may have to do it couple of times.
thanks for that tried, everything, think its a dud, feels like it has nothing inside of it lol, sending it for a return, i guess ill try again
Did you put batteries into it ?
