[TESTING][S905(X)] 10bit/HDR/Dithering Test Builds & Discussion
- johngalt
- Thread is Unresolved
Is there a full functional SimpleIPTV Addon for Testing 8?
Gendo Can you compile one please?
Thanks in advance.
Thanks I will try it in the evening and will report.
Dropbox - pvr.iptvsimple-999.3.2.2.2.zip
Update: Works. Thanks.
Netflix doesn't play anything using test8.
My S905X Device (M9S) seem to have an unsupported HDMI CEC Adapter, since I am always greeted with the "Couldn't initialize Pulse Eight HDMI CEC Adapter - Check your settings" when starting LibreELEC.
Why am I writing this into a HDR/Dithering/10bit test thread?
Because the error message seems to be gone in the test release(s). But the HDMI CEC still doesn't seem to work, because my TV stays in idle mode, when I shut down my box. All other boxes are shutting down the TV aswell.
So I wanted to ask: is there anything I could report/test/help, so that we can get the CEC working? -
All S905(X) devices use the same driver ("adapter"), there is no possibility that one of your devices needs something different.
Things to check:
- device tree
- HDMI cable
- you can try using one of my builds
It's also possible the board of your box is broken. Does CEC work in Android?
So I wanted to ask: is there anything I could report/test/help, so that we can get the CEC working?I get that error when there are other active hdmi devices aside from the s905 box connected to my TV, so I just ensure that the only active device is the android box and the other devices are turned off.
Things to check:
- device tree
- HDMI cable
Since it's S905X I stayed on the standard device tree.
HDMI cable is also the same I used when setting up the other 3 boxes (Beelink MINI MXIII II, Beelink Mini MX Ver 1.0, Sunvell Q-Streaming), but I will change it. Trying one of your builds? Like the 8.0e and 8.1.4 builds? Tried before (always with a clean build, always with the error code) only the Leia Testing builds don't show the error.I get that error when there are other active hdmi devices aside from the s905 box connected to my TV, so I just ensure that the only active device is the android box and the other devices are turned off.
For setting up the devices, all other HDMI CEC devices are shut down.
For me too. Will be there a fix?
New build based on JGalt's repository + kodi master + inputstream master + latest kernel
Dropbox - LibreELEC-S905.arm-9.0-Leia-testing.tar
updated
Is vfs rar addon included ?
This version DOES have Netflix in 720P with DD+. thanks
No
updated
What's in the updated version?
working pvr addons
working pvr addons
Sad to say it doesn't work. Not with the available plugin nor with the one provided in this thread.
which addon do you need?
Dropbox - pvr.dvbviewer-999.3.3.1.2.zip
PVR IPTV Simple. Sorry, didn't know there was a new package.
