LibreSpot Add-on
  • Thanks for the fast response.
    I can`t change the output in the addon settings. It displays "Programs" but I can`t change anything using the arrows, neither in the ALSA tab.
    I`m using a Raspi3 with Milhouses` nightly, librespot version is 8.1.102b
    Milhouse nightlies are based on LibreELEC master (9.0), Librespot 8.1.102b is based on LibreELEC 8.1: your configuration is unlikely to work at all, because of mismatched libraries.
  • Can it be that Spotifiy is blocking librespot (again)?
    INFO:librespot::session: Connecting to AP "lon3-accesspoint-a33.ap.spotify.com:4070"
    thread 'main' panicked at 'Authentication failed', /home/chewitt/LibreELEC.80-addons/build.LibreELEC-Generic.x86_64-8.0-devel/librespot-aa86ebf/.x86_64-libreelec-linux-gnu/x86_64-unknown-linux-gnu/release/build/librespot-e68a0fa7c741f792/out/lib.rs:365
  • Hi there,
    I installed the addon today
    But I've got the same error as RealZac is describing, when clicking on my device in the Spotify app on my phone, I monitored the service and it says
    INFO:librespot::session: Connecting to AP "lon2-accesspoint-a7.ap.spotify.com:4070"
    Did I do something wrong? Wrong settings perhaps?
  • It worked yesterday. So I'm pretty sure Spotify is blocking it.
  • This addon is awesome!
    only problem I have is that my PC detects librespot as a player device but my android phone doesn't (LineageOS 7.1) .
    If I stream music from my PC to LIbreELEC (RPi2) then Librespot appears also in my phone and I can play/pause songs but if I switch off my PC librespot disappears from my phone's spotify device list...
    it is so weird...
  • This works great on my C2/arm! Virtually every isse is gone. It reacts reasonably fast to my phones control (skip, play/pause) and seeking is also working flawlessly done from my phone. Only glitches I see so far are that the shown elapsed time, which Kodi shows in current playing track (librespot) is always 2s ahead of the actual timestamp of the track: "04:11/4:13"- So the time after the slash is not that what I would expect, but that's not important.
    Second thing is that "shuffle" and "repeat" buttons in Android app have no effect if pressed.
    Awesome work, especially this 102b version!
    I've tried using Librespot addon on my RPi 2 (LibreElec, Kodi 17.3) for a several days (always the latest version) and some issues still occur no matter what I do:
    – when I boot up my RPi, LibreSpot is not "active" or at least on my phone/mac it's not visible as a spotify connect device –> to solve this I have to go to addon settings, re–enable the addon and then it works (however not always)
    – when I chose Kodi as a output device any sound was not played at all
    – when I finally managed to get it visible for my devices it crashed after a few songs played
    – time to time happnes that it's visible and no sound comes out of it
    Any suggestions? Thank you!
  • Try latest preview.
    If problems persist, please provide system information and a log (journalctl -u service.librespot)
