is there a fix for the boot loader yet? box is bricked. mx2 midnight.
Amlogic(MX2/G18) 8726MX-Krypton-LE-8.0.1-Images
Demetris -
April 4, 2017 at 1:20 PM -
Since one of my cousins happens to have an MX2 and he asked me to produce an LE image for it here it is.
I dont own the device & images here are the least untested by me.
Beware dragons ahead...After all said and done Enjoy my images based always on the excellent work of kszaq.
Download Links for 8.0.1
downloads for Amlogic MXQ TV Box by Demetris. | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers- Using the latest 3.10.105 LTS kernel
- Compiled and optimized for cortex A9
- No need to rename partitions boots by default into correct one
- Fixed CEC support
-Using the latest known bootloader recovery and logo images 18/05/2016Removed as it was causing hard bricks 12/04/2017The files don't seem to exist in on the link provided, are you able to repost? Thanks for your hard work Dementris.
I will repost with bootloader fix solution asap.
Edit:New Images are up!Sent from the Island of Venus
Demetris how do I use this? I tried to burn the img using usb image tool and tried to revive my box. I noticed there were no recovery.img and no zips on the FAT32 partition.
Do you have a flashable zip version as well? -
Thanks but how do I bring the box back to life? Will the gz file fix it? Obviously I can't use the .tar update one. Thanks in advance.
Didnt upload bootloader fix yet
Cheers mate. Any idea on when or if you will upload it? Thanks
Didnt upload bootloader fix yetSent from the Island of Venus
Do you have an idea when you will upload this please? Need to bring my box back to life.
I managed to bring my unit back to life by loading the revert to android fix from the lads at ember. Load this on an SD card and do the toothpick method (although my screen stayed black after flashing grey for a second). I left running for 5 minutes, then loaded the 7.0.2 LE release using the same toothpick method and it came back to life.
Dementis - I'm really looking forward to the boot loader fix
I'm trying this now. I never get to see the recovery screen though. Black scree - no signal. Was this the same for you? I'll keep you updated on whether this works for me.
No, mine's still stuck on a black screen -
No, mine's still stuck on a black screenYep it was a completely black screen until I loaded the older version of libreelec afterwards.
Tried your solution, but still no signal. I'm glad you could fix yours. Hope to fixe mine one day -
I will upload a fix image later tonight.
Στάλθηκε από το Moto G 2014 μου χρησιμοποιώντας Tapatalk
Sorry, I mis-understood you. Which 7.0.2 did you use?
Recovery options are up, regards
MX2 Bootloader fix
https://www.androidfilehost.com/?w=files&flid=171595
- Extract MX2.img.zip
- Burn to sdcard
- Boot
2nd way
Extract mx2-boot-recovery.zip
Burn uboot.bin to sdcard using Amlogic bootcardmaker.
After finish extract "EXTRACTME_g18ref-mx2_Android_Revert.zip" or any compatible rom for your device to sdcard
Boot and flashThe good news is that it is actually possible to recover from the bootloader brick. However all provided solutions seems to be incomplete.
1. The MX2.img.zip solution:
- the extracted .img file is not actually a RAW disk image file but rather a compressed image file format from HDD Raw Copy Tool
- it can be burned to SD card ONLY by HDD Raw Copy Tool (using any other software will result in a corrupted SD card)
- you have to rename the MX2.img to MX2.imgc before opening it in HDD Raw Copy Tool
- however even then I was not able to use the SD card to recover my device2. The mx2-boot-recovery.zip solution:
- this solution is essentially the good one but it is very briefThe essential part is that we need to write the bootloader to MBR of the SD card. More complex and working guide can be found at [HOW-TO] Unbrick DroidTV MX (the second solution).
Rufus can burn RAW images, no?
Thank you so much guys i finaly fixed it. Here is how I did it:
- I downloaded the mx2-boot-recovery.zip and extracted it.
- Then I used the sd card maker and selected the uboot from the mx2-boot-recovery
- Then after making the sd card I copied all the files from mx2-boot-recovery to the sd card
- I used the toothpick method to boot my box into recovery, once in recovery you can flash anything you like -
