  • Hey,
    I cant use channel 136 on the 5Ghz wifi (anymore). Other 5Ghz AC channles are working and in Android 7.1 channel 136 does work correct.
    iw list:
    Frequencies:
    * 5180 MHz [36] (0.0 dBm)
    * 5200 MHz [40] (0.0 dBm)
    * 5220 MHz [44] (0.0 dBm)
    * 5240 MHz [48] (0.0 dBm)
    * 5260 MHz [52] (0.0 dBm)
    * 5280 MHz [56] (0.0 dBm)
    * 5300 MHz [60] (0.0 dBm)
    * 5320 MHz [64] (0.0 dBm)
    * 5745 MHz [149] (0.0 dBm)
    * 5765 MHz [153] (0.0 dBm)
    * 5785 MHz [157] (0.0 dBm)
    * 5805 MHz [161] (0.0 dBm)
    * 5825 MHz [165] (0.0 dBm)
    Supported commands:
    LibreELEC:~ # iw reg get
    global
    country 00: DFS-UNSET
    (2402 - 2472 @ 40), (6, 20), (N/A)
    (2457 - 2482 @ 40), (6, 20), (N/A), PASSIVE-SCAN
    (2474 - 2494 @ 20), (6, 20), (N/A), NO-OFDM, PASSIVE-SCAN
    (5170 - 5250 @ 160), (6, 20), (N/A), PASSIVE-SCAN
    (5250 - 5330 @ 160), (6, 20), (N/A), DFS, PASSIVE-SCAN
    (5490 - 5730 @ 160), (6, 20), (N/A), DFS, PASSIVE-SCAN
    I think I could use channel 136 in LE before upgrading the box to android 7.1.
    What can I try?
  • It depends :)
    I bought three boxes - see signature
    In my case is S912 box the best choice, but what is Your case ?
    Thanks! It's not for me but I have been asked by some friends which one is best right now and I'm not sure. I'm really happy with my S905X but I'm not sure if there's anything better by now. I suppose there is, since it's a somewhat old soc. Anyway, I'll discuss it in the appropriate thread.
  • I've read OP's warning so I've been telling them no but I read the buying guide post and it says the issues were fixed.
    The issues are still present but there are workarounds that make S912 work much better. My recommendation to not buy S912 for LE is still valid.
  • Hello everyone,
    I have a issue with my friend's Beelink G1 (not ultimate) S912 box. The device is with 2GB of RAM, 16GB internal storage and 1Gigb Ethernet adapter. I run this build and everything works great except the Ethernet port. I've tried all devices tree, even and default one as I tried to delete it from the SD card with the same unsuccessful result. I saw that nobody has the same problem with this box. I'll be very happy if someone knows where the problem is.
    Thanks in advance and good day to you guys. :)
  • LibreELEC "is" Kodi
    to update kodi download the newer LibreELEC version, either tar or gz.img & copy to the update folder on the device, then reboot.
    I have version 8.1.10 on my H96 Pro + now and only want to update tot the newest 8.2.1.1 version with Krypton 17.6.
    I want to keep all my addons and settings.
    On my ipad I can acces the update folder by using samba on Filebrowser (LibreElec/Update)
    Do I only have to unzip the gz.img folder and copy/paste that file in the Update folder and then reboot the device?
    I even could do this on an Ipad.
    Can you downgrade on the same way?
  • Do I only have to unzip the gz.img folder and copy/paste that file in the Update folder and then reboot the device?
    You can even just drop the tar in there without the need to unzip anything. Just be a bit more patient during the reboot.
    Yes
  • Just be a bit more patient during the reboot.
    Really? I thought the tar is the faster one.
    pel.hu
  • kszaq, I have a problem with the LAN connection on my Beelink GT1. The Wi-Fi works fine but it doesn't work with cable.
    I use version 8.2.1.1 with default .dtb
    I have also tried with gxm_q200_1g.dtb , gxm_q200_2.dtb, gxm_q200_3g.dtb and it only worked with q200_1g again with no cable connection, only Wi-Fi.
    Do you think using an older version could solve the issue with the cable?
  • Hello everyone,
    Also using Beelink GT1(not ultimate). Everything works out for me regarding ethernet. Using dtb for gigabit & 2gb ram. Have you put it in the root of sd card? deleted the old one and renamed the new? everything is in the quide. Once again kszaq you rock man!
  • Off topic, do you know if I can boot LibreElec from USB flash drive to Wetek Play 1? Official image or yours (if you have one).
    As far as I know, it's possible only with SD card.
  • Really? I thought the tar is the faster one.
    I meant compared to decompressing it manually before putting it in the update folder ;) In this situation the reboot itself will be faster because it won't have to unpack the update first.
