I'm having issues with unblockr and the addon.
It used to work great not sure what happened.
Here is the current log file for addons
Any help would be great.
# ... output of cat /storage/.kodi/userdata/addon_data/script.openvpn/openvpn.log
# LibreELEC release: Generic.x86_64-9.2.0
Sun Dec  1 12:47:46 2019 WARNING: Using --management on a TCP port WITHOUT passwords is STRONGLY discouraged and considered insecure
Sun Dec  1 12:47:46 2019 OpenVPN 2.4.7 x86_64-libreelec-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] built on Nov 22 2019
Sun Dec  1 12:47:46 2019 library versions: OpenSSL 1.1.1d  10 Sep 2019, LZO 2.10
Sun Dec  1 12:47:46 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]91.206.183.247:1194
Sun Dec  1 12:47:46 2019 UDP link local: (not bound)
Sun Dec  1 12:47:46 2019 UDP link remote: [AF_INET]91.206.183.247:1194
Sun Dec  1 12:47:47 2019 [vpn.unblockr.net] Peer Connection Initiated with [AF_INET]91.206.183.247:1194
Sun Dec  1 12:47:49 2019 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Sun Dec  1 12:47:49 2019 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.255.1
Sun Dec  1 12:47:49 2019 TUN/TAP device tun0 opened
Sun Dec  1 12:47:49 2019 NOTE: unable to redirect default gateway -- VPN gateway parameter (--route-gateway or --ifconfig) is missing
Sun Dec  1 12:47:49 2019 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sun Dec  1 12:47:49 2019 Initialization Sequence CompletedI uninstalled the addon and reinstalled it is working now. Upon setting up the user defined I selected "no" to the option that pops up.
	 and the log just gives me a 1 line error mentioning -killall
