Display MoreHave you changed both lines with 166?
key_begin
key_end
Also try to delete or block with # these ones:
ok_key_scancode = 0x55
pageup_key_scancode = 0x04
pagedown_key_scancode = 0x1b
Ok that seemed to get the OK button back to normal after hitting stop/mouse. One last problem. After hitting stop/mouse it disables key repeat until i hit mouse again. For example if i press down arrow to quickly scroll through a list of movies it only goes down one press at a time instead of scrolling down fast while holding. If i hit mouse again, key repeat returns.
This is what I have now:
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0xff000001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 0
fn_key_scancode = 0x17
left_key_scancode = 0x47
right_key_scancode = 0x15
up_key_scancode = 0x46
down_key_scancode = 0x16
#ok_key_scancode = 0x55
#pageup_key_scancode = 0x04
#pagedown_key_scancode = 0x1b
mouse_begin
# 0 0x47
# 1 0x15
# 2 0x46
# 3 0x16
mouse_end
key_begin
0x18 116
0x54 2
0x48 3
0x7 4
0x50 5
0x12 6
0x11 7
0x4c 8
0xe 9
0xd 10
0xc 11
0x4b 14
0x6 172
0x46 103
0x40 1
0x47 105
0x55 28
0x15 106
0x4 139
0x16 108
0x17 166
0x14 114
0x8 113
0x10 115
0x42 119
key_end
repeat_key_begin
0x18 116
0x54 2
0x48 3
0x7 4
0x50 5
0x12 6
0x11 7
0x4c 8
0xe 9
0xd 10
0xc 11
0x4b 14
0x6 172
0x46 103
0x40 1
0x47 105
0x55 28
0x15 106
0x4 139
0x16 108
0x17 166
0x14 114
0x8 113
0x10 115
0x42 119
repeat_key_end
