Hi folks,
I've had this problem on the WeTek Hub, but I thought it was due to the maturity of the build for the little box.
Now I've installed LibreELEC 7.0.3 on my old Zotac Zbox (Intel Atom + Geforce 520M) which worked perfectly with old OpenELEC, and the audio delay has appeared there too!
I should point out that the video files themselves are fine, they work fine in Windows media player, VLC, and under OpenELEC.
Since I did a clean install it's possible that I'm missing some configuration options, but I haven't seen anything.
Does syncing refresh rates cause audio delays?
I have a Denon AV receiver and I've enabled passthrough and I've ticked all the boxes since the receiver is capable of all formats.
Any way to fix this? If a fix works on the intel platform then it might work on the WeTek as well!
Thanks!
I've found something here that makes me wonder - does passthrough only work when you select 2.0 output?! I have a 5.1 system and 7.2 capable receiver. What settings should I use?
