I'm DONE with the the S905X Chip Boxes.
I don't really think we can tar every S905X box with the same brush, because you have had two (from the same Manufacturer) that have failed ![]()
Have you tried shorting the nand pins to erase / reset it?
I've researched a bit more on why these S905X Boxes are cheaper than S905 Chip Boxes and discovered the Circuit Boards are the first
crap shortcut in Quality and that is a Major no no for me.
Your conclusion is false.
There are very shitty boxes with S905 even with fake RAM chips and there are very good boxes with S905X (like the M8S II or MINI MXIII II)
I received this week a new Q-Box (S905, 2GB / 16GB, 1GB Ethernet). I installed 7.0.3.012i temp_sensor_disabled succesfully to NAND. It works using the default device tree but also with gxl_p212_2g_nand.dtb. I'm guessing it's actually an S905x box because of this.
The problem is powering the box off. The red power button on the box reboots the box. Using the power menu results in this behaviour:
When doing a suspend, wake up and performing a shutdown the box actually powers down (led light goes off). It can be powered on again using the red power button.
I've tried all tricks I know to make this box shutdown such as using a custom shutdown.sh script. When using SSH using commands such as: halt, shutdown-P, the box doesn't properly poweroff (reboots or even hangs). It is not possible to make a script for first performing a suspend and then a shutdown, simply because after a suspend no more script code is executed.
Any ideas how to make the box powerdown properly and in 1 action?
I received this week a new Q-Box (S905, 2GB / 16GB, 1GB Ethernet). I installed 7.0.3.012i temp_sensor_disabled succesfully to NAND. It works using the default device tree but also with gxl_p212_2g_nand.dtb. I'm guessing it's actually an S905x box because of this.The problem is powering the box off. The red power button on the box reboots the box. Using the power menu results in this behaviour:
- Shutdown: results in a reboot
- Suspend: brings the box into sleep (led light stays on)
When doing a suspend, wake up and performing a shutdown the box actually powers down (led light goes off). It can be powered on again using the red power button.I've tried all tricks I know to make this box shutdown such as using a custom shutdown.sh script. When using SSH using commands such as: halt, shutdown-P, the box doesn't properly poweroff (reboots or even hangs). It is not possible to make a script for first performing a suspend and then a shutdown, simply because after a suspend no more script code is executed.
Have you checked the ethernet (it's really gigabit)?
I've never seen an S905X box with gigabit lan. If yours has gigabit I would buy one right now. Could you give a link where you bought it? (In PM)
Have you tried to hold the power button for a few seconds?
You probably still haven't . . .
My TX5Pro's that SH#T themselves have Samsung RAM. Qualcomm wifi Blah Blah.
I'm just making a point on the Board.
The Board looks like recycled Dogsh#t .
2 sided circuit board.
Enough! Start a new thread if you want to take this further.
2 sided circuit board i cant see any numbers or know of schematic diagram.
Supplier asked for me to send them back to "Shenzhen Sally" who will get her Engineer "Hong Kong Harry"
to tell me what happened? I will report back. ![]()
I would like to know too! All other device trees without 1GB LAN resulted in no working Ethernet connection. Sometimes it received an IP address (starting with 169.) but no connectivity. In my experience this happens when the device tree for ethernet is wrong. I tied all device trees for boxes with 2GB on board. Do you have any pointers for me how to test if the ethernet is actually gigabit?
The box doesn't have a powerbutton, it is only powered on by remote and off course the powerplug.
And, indeed I'm merely guessing. A previous Q-box I received a month ago didn't work with the S905x devicetree's. This one does, but also with the default devicetree.
I forget to mention a detail. The Android version on the previous box was 5, on the new box it is 6. Maybe the new firmware is the cause?
Read This as well #1
Not very conclusive eh?
Seems to follow the trend we already know of these cheap boxes. Some report great results with a particular type, whilst others don't and vice versa. That's why I'd only pay rock bottom price for them.
Supplier asked for me to send them back to "Shenzhen Sally" who will get her Engineer "Hong Kong Harry" to tell me what happened?
LOL
I can't follow you.
The lan is working with gxl_p212_2g.dtb, isn't it?
if yes and the android 6.0 os indicates that it is probably an S905X.
(As I know the default dtb contains 4 dtb: p200 1g/2g and p212 1g/2g.)
How to check your lan:
1. From a terminal you can use the 'ethtool eth0' command to see the capabilities of your lan.
2. You can open your box and check what lan chip is inside (or take a photo and share here).
3. You can check your router's connections, some lists the connected devices' speed.
Thanks for this! This resulted in:
Supported ports: [ TP AUI BNC MII FIBRE ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 8
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
Display More
So, the speed is actually 100 mbps
Bummer.
Might this be because I have the wrong device tree, with no support for S905x, 2GB AND 1 gigabyte Ethernet?
And could this explain the issue of not wanting to power down?
Your box would not boot if you flashed a device tree for wrong ethernet speed.
OK, I'll tell you which device trees I tried. I managed to install using the following device trees. LibreElec booted, but ethernet connected through a weird IP (169.* instead of 192.*) and no data came through. Wifi didn't work either.
The following device trees didn't work (LibreElec would startup from SD)
The only device trees which resulted in Ethernet with a working connection and Wifi were:
Maybe this gives a hint which hardware is in the box and why I have powering down issues.
It seems your box has S905X and 100Mbit lan.
I can live with that. The biggest problem I have is that the boxes don't power off. Any idea how to fix this?
Have you tried the long press I suggested before?
Have you triedthe power off method settings in LE?
kszaq, which kernel build do you use in those builds ? Probably can check it somehow but I'm away from home and not able for some time...
Two noob questions...
This is based on Linux like libreelec for Rpi?
It's possible Install Acestream?
GitHub - kszaq/linux-amlogic-le: the Linux kernel for Amlogic SoC devices
