Tvheadend nightly builds for LE
  • the folder 9.2 contains builds for LE 9.2 (currently 9.1.002)
    - we have there no AML anymore (till LE10 with proper new drivers/kernel) so there are no builds for LE9.2 based at aml
    the folder 9.0 contains builds for LE 9.0 (currently 9.0.x)
  • the folder 9.0 contains builds for LE 9.0 (currently 9.0.x)
    I hate to sound like a broken record, but could you kick the build system to build a newer tvh for 9.0?
    Otherwise, is there an easy way to just cross-compile it without building the whole distribution?
    TIA.
  • but could you kick the build system to build a newer tvh for 9.0?
    not that easily because my build server has just limited resources and I can't build 9.0 + 9.2 at the same time due storage problems
    yes (first time ~1h, second time with filled cache ~2-3min)
    1. git clone https://github.com/CvH/LibreELEC.tv.git LE-Tvh
    2. cd LE-Tvh
    3. git checkout 9.0/tvh-4.3
    4. PROJECT=Generic ARCH=x86_64 scripts/create_addon tvheadend42
    ^^^ example for Generic, for other archs see here Compile [LibreELEC.wiki]
    then edit packages/addons/service/tvheadend42/package.mk
    change PKG_VERSION to the commit from Tvheadend git
    PKG_VERSION_NUMBER is not that important but could be manually adjusted too
  • Hotbird 13E
    With Tvh 4.3 there is no sound on the MyZenTv 4K channel. With Tvh 4.2 there is sound on the MyZenTv 4K channel.
    I use Denon AVR .It also works with Tvh 4.3 when I connect it directly to the Tv. Sometimes the sound is cut of.
    Edited 4 times, last by crazyturk ().
