Tvheadend nightly builds for LE
  • As I am using the service name picons for me it's something like this file:///storage/picons/tvh/daserstehd.png
    But as I said in the browser looking at the details in EPG the Picons are there. Also http://serverip:9981/imagecache/20 shows the correct image for channel 20. So for some reason it's not making the way to Kodi. Also setting up a path to the picon folder in Kodi doesn't work.
    are you sure there are no spaces?probably picon names and services names are not matching
  • Where should be spaces? I think the names are matching. All picon paths are autogenerated. When I change something the pcions are gone. For some channels I checked the file in libreelec too. I would assume it's maybe a problem on the client side.
    I use the TVheadend HTSP Client from Adam Sutton et al. in version 4.4.16.1
    Edited once, last by tuep ().
  • FWIW with the 4.4.16.1 client I had some of the channel icons that didn't correspond to the correct one. They also didn't change when I changed some icons (coming from the epg). Finally deleting the Thubnails directory "fixed" the icons.
    No such problems with the 4.4.17 client that I have on an ubuntu laptop. Unfortunately 4.4.17 isn't available in the libreelec addons repository.
    Try this works well amlogic! KI Pro.
  • Can't install. The message is:
    Addon couldn't be loaded. An error occured.
    Is there a problem with this file. I just downloaded it and tried to install it. Sometimes I get too trustfull ...
    As said before the same and compiled to run in amlogic, I do not know if it will work for you here is up and running!
  • for some reason my webspace was disabled from the hoster, looks like I forgot to change my billig information (changed my bank account recently) ....
    try to fix it tomorrow
    Hi CvH , i have a cPanel server (UK) - I don't mind giving you an account for free if not too much bandwidth and storage space used. What is your typical usage ?
    Feel free to PM me !
