Last updated November 13, 2026
Download hadesdevls LE builds here.
Video using hadesdevls RC8 build:
All the issues shown in it have been resolved, with significant new features and enhancements, as of post-RC v1.0. See examples later in this thread.
Recommended general settings:
| Setting | Recommended |
| Hardware acceleration — VAAPI | ON |
| DRM PRIME decoder | OFF |
| DRM PRIME hardware acceleration | OFF |
| PRIME Render Method | EGL |
| Render path | EGL / VAAPI Kodi support for DRMPRIME was designed for ARM SoC hardware using direct-2-plane rendering. With Intel/AMD, only use EGL/VAAPI |
| Direct-to-Plane / D2P | OFF |
📖 Read here for all Hades' specific settings and what they mean ⚙️
Guidance from hadesdevls:
Installing
For an easy install from Windows, you can use the installer made for Hades (LibreELEC-Hades-Installer.exe, from the release page, with the .img.gz and .sha256 next to it). Any other image writer like Rufus or balenaEtcher works too with the .img.gz.
Reporting problems
Please report problems in the GitHub issues, not to LibreELEC or Kodi. Say which graphics card and TV you have, how they're connected, and what you were playing, and attach a diagnostic report from Settings > LibreELEC > System > Submit Log > Create a diagnostic report.
CroqueMr's builds thread can be found here.
