I think that AMD cards can support vaapi via mesa - but I don't have an AMD card to test / confirm on. If we can confirm that works then we should be able to use one path for both playback paths.
Yes AMD card support VAAPI, DV playing works great on my 7430U (just a small issue on Profile 5 but it is easy to fix), this is why I prefer to not use a 2nd path for Intel, and try to capitalize on optimization that benefit both Intel and AMD.
I have some free time, so I’d like to integrate your changes as soon as possible while waiting for the fixes coming via the issues. If that works for you, I’ll go ahead and integrate your two major enhancements; it shouldn't take long, as I can see how to do it cleanly.
Tried it but curiously all DV and HDR related stuff appeared as "/unavailable" on my N100... on the same hardware that had everything working in release R0.3.0. So I can't even play test it.
As a side note. I tried both dangerouslaser and R0.3.0 CroqueMr build on "Tron Ares" (a DV P7 highbitrate REMUX) and on both I get the same 1 frame drop per second. So it seems that lightweight file test or gigantic movie file size really don't matter.
The issue on the frame dropping is almost fixed, the next release will address it.
Could you send me the kodi.log file? I ramped up the fallback mechanisms so that even devices without DV support could use the build and play DV content via HDR10, I might have been a bit too aggressive with that.
