What do you mean? My build had 17.1 at day 1
escalade -
May 12, 2016 at 2:26 PM -
Thread is marked as Resolved.
I'm an idiot. Thanks.
that would be awesome if could get streets of rage remake to work with LE8.
Got this installed and it works great. Thank you very much.
Sent from my SM-G930V using Tapatalk
Hi escalade,
just one question to a problem I have since upgrading to your latest build:
While I was able to play bluray back with the makemkv-addon on one of your older releases (about december), it`s not working for me on the actual version anymore.
I did not make changes to the makemkv addon.Should it work ?
Thanks !
Best regards,
Thomas -
Yeah, it's supposed to work although I don't have a bluray player to test. You can look at /etc/profile.d/99-kodi.conf to see the variables that are set up to make it possible. I haven't changed anything regarding this.
Mr. escalade ... Do you know if the /STORAGE partition can be formatted with extFAT or FAT32 to have ROMs/BIOSes, updates, etc....?
I have a Late 2013 Retina MBP with a Corei7 + Intel Graphics & discrete NVidia GT750M and want to dual-boot it with refind and access to Storage partition from macOS to try your excellent fork of LE with real (little old)power to play dolphin..!
Cheers!
Mr. escalade ... Do you know if the /STORAGE partition can be formatted with extFAT or FAT32 to have ROMs/BIOSes, updates, etc....?I have a Late 2013 Retina MBP with a Corei7 + Intel Graphics & discrete NVidia GT750M and want to dual-boot it with refind and access to Storage partition from macOS to try your excellent fork of LE with real (little old)power to play dolphin..!
Cheers!
Mmm... Already find your answer on a different thread hehe.. Thanks anyway!
Hi newbie here, Using RPi2 image when systemctl enable transmission I've got "Unit transmission.service not found"
how do I enable transmission?
Thanks -
Using an Z97I-PLUS board I couldn't get bluetooth to work with its integrated controller.
Looking at DMESG output I notice there is a reference to a missing file: BCM20702A1-0b05-17cf.hcd
Display MoreLibreELEC:~ # dmesg | grep -i blue [ 2.801891] Bluetooth: Core ver 2.22 [ 2.801896] Bluetooth: HCI device and connection manager initialized [ 2.801898] Bluetooth: HCI socket layer initialized [ 2.801899] Bluetooth: L2CAP socket layer initialized [ 2.801901] Bluetooth: SCO socket layer initialized [ 2.817332] Bluetooth: hci0: BCM: chip id 63 [ 2.833175] Bluetooth: hci0: LibreELEC [ 2.834750] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000 [ 2.834915] bluetooth hci0: Direct firmware load for brcm/BCM20702A1-0b05-17cf.hcd failed with error -2 [ 2.834916] Bluetooth: hci0: BCM: Patch brcm/BCM20702A1-0b05-17cf.hcd not found [ 2.894888] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.894889] Bluetooth: BNEP filters: protocol multicast [ 2.894891] Bluetooth: BNEP socket layer initialized [ 7.052233] Bluetooth: RFCOMM TTY layer initialized [ 7.052236] Bluetooth: RFCOMM socket layer initialized [ 7.052238] Bluetooth: RFCOMM ver 1.11
After manually inserting that file into SYSTEM image and trying again, I can confirm it works fine now with a PS3 controller.
Log with firmware present:Code
Display MoreLibreELEC:~ # dmesg | grep -i blue [ 2.646980] Bluetooth: Core ver 2.22 [ 2.646990] Bluetooth: HCI device and connection manager initialized [ 2.646992] Bluetooth: HCI socket layer initialized [ 2.646993] Bluetooth: L2CAP socket layer initialized [ 2.646998] Bluetooth: SCO socket layer initialized [ 2.656557] Bluetooth: hci0: BCM: chip id 63 [ 2.673510] Bluetooth: hci0: ubuntu [ 2.674556] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000 [ 2.753927] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.753928] Bluetooth: BNEP filters: protocol multicast [ 2.753930] Bluetooth: BNEP socket layer initialized [ 3.309599] Bluetooth: hci0: BCM20702A1 (001.002.014) build 1469 [ 3.326041] Bluetooth: hci0: Broadcom Bluetooth Device [ 6.866824] Bluetooth: RFCOMM TTY layer initialized [ 6.866826] Bluetooth: RFCOMM socket layer initialized [ 6.866829] Bluetooth: RFCOMM ver 1.11
Would it be possible to add this firmware into next builds so it works out of the box on this motherboard?
Sure, send me a PR
hey escalade, how i can use a XBox One Wireless Controller with Dongle on your Build? i see the Dongle in Bluetooth-List but i can't pair. The Dongle don't "blink" and no pair with controller. Can you help me or give me a link to an tutorial or something? i want to use the controller for moonlight-addon (PS3 don't have any function in games :() i hope you know that issue
Sorry, I don't have one.
edit: fixed it
Just copied picodrive_libretro.so from another source rather than using the online update version.Hello, great build escalade! Tbh the best build i've tried so far.
Anywayz, i'm trying to play some sega32x games but without luck.
I used the retroarch online updater to download the picodrive core, i made a folder with some roms and edited the es_systems.cfg as shown.Code<system> <name>sega32x</name> <fullname>Sega 32X</fullname> <path>/storage/roms/sega32x</path> <extension>.32x .bin</extension> <command>/usr/bin/retroarch.start -L /tmp/cores/picodrive_libretro.so %ROM%</command> <platform>sega32x</platform> </system>
Then i chmod 755 the picodrive_libretro.so.
When i try to load a game the screen goes black and the orange led on the pi flashes for more than 5 secs.
Then i need to push the quit retroarch button i've set 2 times and it goes back to emulationstation.What i'm i missing? All other emulators work just fine.
P.S: To be of some help to others too, for the sound to work in emulation i added
along with the hdmi_drive=2
After long Google search i found the answer for Xbox one s wireless controller
echo 1 > /sys/module/bluetooth/parameters/disable_ertm
Can you it impliment in your build escalade? I think it will be help some other people to play games with Xbox one s controller wireless
For anyone who is using another skin like me (aeon mq7 mod)
I have created a shortcut addon to start Emulationstation, Spotify and Chrome
Just install the correct addon and launch the addon from anywhere
Spotify
edit1:I did a fresh install but when i want to launch dolhpin it does nothing
in the dolphin.log i find thisQuote
GNU nano 2.5.3 File: dolphin.log
dolphin-emu: error while loading shared libraries: libLLVM-3.9.so: cannot open $Any idea's ?
edit 2:
It seems to be in my backup to -
Would it be difficult to exchange Dolphin with Ishiiruka?
How could I do that? -
