Hey!!
This version looks like a lot of fun! Thanks a lot for your work. Is there any chance that in the near future is going to be a version for Cubox-i?
Thanks a lot!
Hey!!
Thanks a lot!
Just a question to Intel NUC users with Retroarch : what do you guys think performs best in terms of input lag and general performance : KMS/DRM or Vulkan ? Thanks !
guys any body knoq how i can make usb hdd sleep when i not use them and wake up when i start downloading files with transmission?
KMS is the best, then GL. There's a thread over at the libretro forums about input lag, I've adapted the best settings in this build (just enable KMS as described on first page). Vulkan is currently lagging behind, I wouldn't use it for anything just yet.
Thanks Escalade ; I've read the thread at libretro forums, and I currently use KMS anyways (I just wanted to be sure). ![]()
Hi escalade,
Thanks for your support. Now my controller works perfectly with ES and FS-UAE ![]()
Glad that my RTFM approach of support was of help, I expect nothing less of an Amiga user though ![]()
And again, I have no sound...
I did not change anything, I have sound in Retroarch, but not on Kodi. The output is HDMI as usual...
Edit : found the problem : sound volume was set to the minimum... But I did not change it myself ?
I just bought a Tronsmart ara x5 plus do I install generic or Atom build? Am a little confused
How did you setup the emulator menu in Kodi?
I want to switch the skin of Kodi to Titan, just not sure how you did it in the stock kodi skin
Thanks!
Hi Escalade, I have updated libreelec (on rpi3) after several months and currently I have an issue with 2 PS3 controllers, basically both are recognized either in Kodi/LibreElec or Emulationstation but for some reason only one is recognized directly in emulator (retroarch). For example if I run some nes game where 2 players can play simultaneously they are both controlled by one ps3 controller.
This was working (and still is working as I have old backup) without any issue in the old image with old retroarch:
LibreELEC:~ # retroarch --version
RetroArch: Frontend for libretro -- v1.3.4 -- 2f7bc87 --
Compiler: GCC (5.3.0) 32-bitBuilt: Jun 4 2016
Do you have any idea what can be the issue in current image and why retrorarch doesn't recognize second ps3 controller?
The weird thing is that it still provides message that ps3 controller in port #0 and port#1 has been configured but it seems that it redirects the both ports just to the first ps3 controller.
the current retroarch version:
RetroArch: Frontend for libretro -- v1.3.6 -- d49502d --
Compiler: GCC (6.3.0) 32-bitBuilt: Jan 5 2017
Hi again,
so I have found what is causing this issue.
In current retroarch.cfg there's input_driver option set to "sdl2". In my previous config this was set to "udev".
After setting back to "udev" ps3 controllers are recognized correctly and independently in retrorarch
"input_driver = udev" is the default setting look at /etc/retroarch.cfg.
Is there a way to customize the bootscreen and insert a new picture?
That has nothing to do with this build so belongs in a separate thread.
Ah okay, I have assumed that you had changed the build, since it is a different picture than in the beta
No I haven't, if there's a new splash in the beta then it's not been commited to git yet.
