Thoradia Add-ons
  • Hello! Sorry for my englisgh, but I need help.
    Trying change rtorrent.rc using "rtorrent-ctl config", but nothing take changes. I need change default directory to save the downloaded torrents and add safe_sync = yes because my torrents are rehashed at every reboot. How can I do it?
  • Thanks for the answer.
    If I make any changes to rtorrent.rc, then rtorrent stops running and rutorrent connects to it. For the purity of the experiment I tried to completely take your option - the result is the same.
  • Your safe_sync isn't working well with it :) When I added this to my rc it stops as well ;)
    If you want to avoid rehashing just stop all torrents and then reboot ;)
    Not sure how to help you with safe_sync
  • I still think that rtorrent incorrectly reads the config. I have uncommented the line:
    directory.default.set = /storage/media
    If I understand correctly, when adding a torrent, it should offer a choice of the contents of the folder /storage/media/ but rutorrent still shows the contents of the folder /storage
    Maybe I need to give some folders access rights via chown or something else?
  • Your torrent got access only to storage ;)
    This is first thing I always do after new installation ;)
    Quote
    ln -s /var/media/ /storage/
  • And the problem with rehashing torrents when rebooting occurs only in me? There is no solution? Stopping them before rebooting does not solve the problem
  • ArtemPoter
    rutorrent does not save settings set from the user interface
    To configure rutorrent/rtorrent edit:
    /storage/.kodi/userdata/addon_data/service.rtorrent/rtorrent.rc
    /storage/.kodi/userdata/addon_data/service.rutorrent/share/
    Keep it legal and carry on
  • Anyone else has a problem with upgrading sickrage?
    I have librelec 8.2 running, and when I try to update SickRage from within the GUI, I always get the following error:
    I already tried setting the directory to chmod 777, any pointers?
    where did you get sickrage ?
    I discontinued SickRage a year or so ago
    Use Medusa or Sonarr
    Volunteers to maintain SickRage are welcome
