Just wondering when 10.0.3 will be out. Thanks.
LibreELEC (Matrix) 10.0.2
We too
Plan is/was to align with kodi release cycle and ship LE 10.0.3 with Kodi Matrix 19.5. But Kodi 19.5 is taking a lot longer than expected.
In the meanwhile feel free to use the latest LE10 nightly builds from here: https://test.libreelec.tv/10.0/ (just copy it to the update folder/share and reboot), they contain lots of bugfixes and also a recently updated kodi 19.5 development version.
I guess, they concrentate to bring the first Beta of Kodi 20.
But, Team LE has decided to bring 10.0.2 independently from Kodi 19.4
Maybe it is a way with LE 10.0.3 HiassofT ?
We have nothing planned/decided yet.
And as it's holiday season and lots of us (and most likely also Team Kodi) are traveling and/or spending time with their families it's unlikely we'll do a LE10 release within the next few weeks.
Finally had the time to upgrade from 10.0.1 and everything is working fine. Its's nice to see that deinterlacing and 10-/12-bit support was added for RPi4.
Should LE10 nightlies be supporting Alder Lake processors now? It's not really clear to me if the kernel was bumped up in the nightlies, cos the latest doesn't run on my Celeron G6900 (is your GPU supported?).
I really don't want to upgrade to LE11 yet.
Details here. https://wiki.libreelec.tv/hardware/intel-x86-64-generic
I run TGL on LE11 as until kernel 5.12 support was not complete.
LE10 uses kernel 5.10.x
Thanks, found one here: RE: Intel true 10bits/HEVC/HDR support... ?
Let's see if this baby boots up with this image
I tried the latest nightly build on my Pi4 but still getting a black screen on the HDMI output. I then tried pastekodi via SSH but I get an error message saying "unterminated quoted string at or near" followed by a very long string of numbers. So again I can't share any debug info here.
Haven't there been others with the same issue in the mean time? The Pi4 has 2 GB RAM. Might that be an issue somehow?
I'm reverting to 10.0.0 again because that is the last build that's running fine.
Just run pastekodi again, sometimes the paste-site has hiccups (I've seen that lots of times myself).
Black screen can have lots of causes, just do a forum search and you'll find plenty of hints and/or answers.
I'll try pastekodi again.
I also get a black screen on a clean flash of 10.0.1 and 10.0.2 (normal builds). Same never happened with 10.0.0 and before. But thanks I'll do a search.
*edit*
This looks like the same issue:
ThreadLE 10.0.1 / Rpi4 / No picture after update from LE 10.0.0
Hi,
after the LE 10.0.1 update of my clean installed LE 10.0.0 from the LibreElec menu and a reboot i get no picture anymore. Only the blue screen of my Onkyo AV.
LE 10.0.0 runs fine since 6 Weeks.
Switched to the other HDMI out of the Rpi4.
Completely shutdown and start again the TV, AV Receiver and the RPi4.
Nothing special added in my config.txt.
Tried to add in cmdline.txt:
video=HDMI-A-1:1920x1080M@60
I can still reach Kodi via SSH and the Android Yatse app. Playing media, controlling CEC via TV…Cris_November 3, 2021 at 10:33 PM Unfortunately no real fixes came out of it (yet..).
Not really sure what else to do. It's just too bad really I can't use the newer builds anymore. The problem occurs on both Pi4's here. Both are connected to LG 4k tv's.
Wow over 6 months no release. What is going on. When will there be a release.
I guess nothing still 19.5 is out.
What is going on.
We got told after 19.4 release there is soon an 19.5, then some months later we gold told the same.
Meanwhile the release manager of Kodi is/was missing in action for some reason. Recently we were told that a new release manager will handle it soon. So we hope there is some movement soon.
Meanwhile you can still install the LE10 nightlies, they are already up to date.
Hi!
rpi3 user here
I moved from 9.2.x (leia) to 10.0.2 (matrix). I did find that the GUI is "slower" than my previous version
Is this normal? It looks like 10.x version is "heavier" that the 9.x (10.x version also boots slower)
Should we wait for better gui performance in future builds among other fixes?
Post
RE: LibreELEC (Matrix) 10.0.2
Hello. Is libreelec 10.0.2 gui supposed to run visibly slower than 9.2.8 on rpi3b+?
I have been using 9.2.8 (and before that older 9.2.x) for quite long time and the gui was just mooth.
10.0.2 looks much sharper but I can feel it is slower (like longer reaction time, something like fps drop, etc.).
note: I performed clean installation of 10.0.2 without loading backup from 9.2.8.ace960March 17, 2022 at 10:33 AM I am staying with 9.2.8 while I can. I found out that I have more h.265 content than I thought.
I personally do not expect performance improvement in future releases for old rpis.
I think that rpi2/3 are no longer optimized.
I'll maybe try newer release (newer than 10.0.2) when/if my 9.2.8 crushes or something else pushes me to upgrade.
