LibreELEC-RPi4.arm-11.0-nightly-20220213-fcba5db is restarting every 20 seconds
  • I tried the recent nightly LibreELEC-RPi4.arm-11.0-nightly-20220213-fcba5db and notice it's rebooting every 20s or so.
    I've Upgraded to previous nightly 20220212 in order to see logs but that to crashed also and has gone into safe mode. I'll paste the log.
    Log is http://ix.io/3Pyu
    Chook
    Update 15 Feb 2022
    I just updated to LibreELEC-RPi4.arm-11.0-nightly-20220215-8a018bd from LibreELEC-RPi4.arm-11.0-nightly-20220212-d203600.
    I'm seeing similar to LibreELEC-RPi4.arm-11.0-nightly-20220213-fcba5db.
    Kodi is rebooting every minute or so and eventually going into safe mode.
    I've pasted another log link here. http://ix.io/3PDH
    Chook
    Rasberry Pi4B 2GB
    Edited once, last by chook55: typo and update. (February 15, 2022 at 3:46 AM).
  • Code
    Feb 14 09:57:29.224658 LibreELEC sh[977]: /storage/.config/autostart.sh: line 1: Bash: not found
    - no experienced log file reader here -
    but
    1. what is in that autostart.sh ? [1]
    2. try without argononed.service and/or autostart.sh
    Edit:
    [1] found the thread "Argon One Fan Control", but TL/DR
    I wonder why a service additionally needs a autostart.sh file doing similar things as the service already does.
    in other words: shouldn't the service and a config [2] file be enough ?
    [2] to adjust "fan speed without needing a brick and earmuffs" :saint:
    Edited 3 times, last by GDPR-7 (February 14, 2022 at 1:49 AM).
  • Joe Average,
    Re ArgonOne
    Probably remnants of the many attempts to get it working. It's never been a problem put fair call. I'll disable it.
    Chook
    I'll past a bit of the 09_Journal log here.
    Says there was a Segmentation Fault.
    Feb 14 09:53:08 LibreELEC nmbd[880]:
    Feb 14 09:53:08 LibreELEC nmbd[880]: *****
    Feb 14 09:53:09 LibreELEC kernel: cam-dummy-reg: disabling
    Feb 14 09:53:09 LibreELEC kernel: vcc-sd: disabling
    Feb 14 09:53:09 LibreELEC kernel: cam1-reg: disabling
    Feb 14 09:53:15 LibreELEC systemd[1]: systemd-hostnamed.service: Deactivated successfully.
    Feb 14 09:53:50 LibreELEC kodi.sh[1022]: Segmentation fault (core dumped)
    Feb 14 09:53:53 LibreELEC kodi.sh[1022]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220214095350.log
    Feb 14 09:53:53 LibreELEC systemd[1]: kodi.service: Main process exited, code=exited, status=139/n/a
    Feb 14 09:53:53 LibreELEC systemd[1]: kodi.service: Failed with result 'exit-code'.
    Feb 14 09:53:55 LibreELEC systemd[1]: kodi.service: Scheduled restart job, restart counter is at 1.
    Feb 14 09:53:55 LibreELEC systemd[1]: Stopped Kodi Media Center.
    Feb 14 09:53:55 LibreELEC systemd[1]: Starting Kodi Media Center...
    Feb 14 09:53:55 LibreELEC systemd[1]: Started Kodi Media Center.
    Feb 14 09:53:56 LibreELEC kernel: hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
    Feb 14 09:53:56 LibreELEC kernel: MAI: soc_pcm_open() failed (-19)
    Feb 14 09:53:56 LibreELEC kernel: bcm2835-i2s fe203000.i2s: I2S SYNC error!
    Feb 14 09:54:34 LibreELEC kodi.sh[1365]: Segmentation fault (core dumped)
    Feb 14 09:54:36 LibreELEC kodi.sh[1365]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220214095434.log
    Feb 14 09:54:37 LibreELEC systemd[1]: kodi.service: Main process exited, code=exited, status=139/n/a
    Feb 14 09:54:37 LibreELEC systemd[1]: kodi.service: Failed with result 'exit-code'.
    Feb 14 09:54:39 LibreELEC systemd[1]: kodi.service: Scheduled restart job, restart counter is at 2.
    Feb 14 09:54:39 LibreELEC systemd[1]: Stopped Kodi Media Center.
    Feb 14 09:54:39 LibreELEC systemd[1]: Starting Kodi Media Center...
    Feb 14 09:54:39 LibreELEC systemd[1]: Started Kodi Media Center.
    Feb 14 09:54:39 LibreELEC kernel: hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
    Feb 14 09:54:39 LibreELEC kernel: MAI: soc_pcm_open() failed (-19)
    Feb 14 09:54:39 LibreELEC kernel: bcm2835-i2s fe203000.i2s: I2S SYNC error!
    Feb 14 09:55:17 LibreELEC kodi.sh[1542]: Segmentation fault (core dumped)
    Feb 14 09:55:20 LibreELEC kodi.sh[1542]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220214095517.log
    Feb 14 09:55:20 LibreELEC systemd[1]: kodi.service: Main process exited, code=exited, status=139/n/a
    Feb 14 09:55:20 LibreELEC systemd[1]: kodi.service: Failed with result 'exit-code'.
    Feb 14 09:55:22 LibreELEC systemd[1]: kodi.service: Scheduled restart job, restart counter is at 3.
    Feb 14 09:55:22 LibreELEC systemd[1]: Stopped Kodi Media Center.
    Feb 14 09:55:22 LibreELEC systemd[1]: Starting Kodi Media Center...
    Feb 14 09:55:22 LibreELEC systemd[1]: Started Kodi Media Center.
    Feb 14 09:55:23 LibreELEC kernel: hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
    Feb 14 09:55:23 LibreELEC kernel: MAI: soc_pcm_open() failed (-19)
    Feb 14 09:56:01 LibreELEC kodi.sh[1738]: Segmentation fault (core dumped)
    Feb 14 09:56:03 LibreELEC kodi.sh[1738]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220214095601.log
    Feb 14 09:56:03 LibreELEC systemd[1]: kodi.service: Main process exited, code=exited, status=139/n/a
    Feb 14 09:56:03 LibreELEC systemd[1]: kodi.service: Failed with result 'exit-code'.
    Feb 14 09:56:05 LibreELEC systemd[1]: kodi.service: Scheduled restart job, restart counter is at 4.
    Feb 14 09:56:05 LibreELEC systemd[1]: Stopped Kodi Media Center.
    Feb 14 09:56:05 LibreELEC systemd[1]: Starting Kodi Media Center...
    Feb 14 09:56:05 LibreELEC systemd[1]: Started Kodi Media Center.
    Feb 14 09:56:06 LibreELEC kernel: hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
    Feb 14 09:56:06 LibreELEC kernel: MAI: soc_pcm_open() failed (-19)
    Feb 14 09:56:44 LibreELEC kodi.sh[2054]: Segmentation fault (core dumped)
    Feb 14 09:56:46 LibreELEC kodi.sh[2054]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220214095644.log
    That kodi_crashlog mentions
    Using host libthread_db library "/usr/lib/libthread_db.so.1".
    Core was generated by `/usr/lib/kodi/kodi.bin --standalone -fs'.
    Program terminated with signal SIGSEGV, Segmentation fault.
    #0 0xf7517efc in ?? () from /usr/lib/libpython3.9.so.1.0
    [Current thread is 1 (Thread 0xcba2e280 (LWP 2202))]
    etc.
    Chook
    Edited 2 times, last by chook55: Merged a post created by chook55 into this post. (February 14, 2022 at 4:21 AM).
  • Im running RPi4.arm-11.0-nightly-20220212-d203600, no reboots, very stable.
    Same here, its 20220213 that caused the crash. I went back to 20220212 but it still crashed. Fortunately I did a backup with a few days ago so was able restore it.
    chook
  • I just updated to LibreELEC-RPi4.arm-11.0-nightly-20220215-8a018bd from LibreELEC-RPi4.arm-11.0-nightly-20220212-d203600.
    Chook
  • Kodi is rebooting every minute or so and eventually going into safe mode.
    Jan 18 22:05:43.554562 LibreELEC kernel: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:27:3D:FB vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  boot=UUID=2710-1204 disk=UUID=a4d75028-811f-4077-8e1e-6cd47fe5eefa quiet
    Jan 18 22:05:43.554617 LibreELEC kernel: Unknown kernel command line parameters "boot=UUID=2710-1204 disk=UUID=a4d75028-811f-4077-8e1e-6cd47fe5eefa", will be passed to user space.
    If you have the skills, edit the kernel params (error before "boot=UUID..."). Otherwise install that nightly from scratch.
  • Code
    OK is this an SSH command line or do I need to edit a file on the RPi or a file in the tar upgrade file? I'm willing to learn but it might be easier to burn to a SD drive.
    chook
  • Code
    I have none of the params before "boot=UUID..."
    Those parameters "coherent... " are injected by the Pi boot loader based on config.txt settings, and then it takes cmdline.txt and appends it when bootstrapping the kernel. So it's normal for a Pi 4.
    Also the Unknown kernel command line parameters is harmless, it is used by the init script in the initrd to mount the disks (the "user space"). This is where $boot is used to mount the /flash partition, just below that there is mount_storage function where $disk is used:
    LibreELEC.tv/init at f42fa56ed8b98f9829d156360b71b0b18de8b86b · LibreELEC/LibreELEC.tv
    Just enough OS for KODI. Contribute to LibreELEC/LibreELEC.tv development by creating an account on GitHub.
    github.com
    It might be useful if you have this log:
    Feb 15 11:47:31.835476 LibreELEC kodi.sh[1725]: Segmentation fault (core dumped)
    Feb 15 11:47:34.440636 LibreELEC kodi.sh[1725]: Crash report available at /storage/.kodi/temp/kodi_crashlog_20220215114731.log
  • frakkin64 Thanks, I'm using RPi 3 stable, so I was just guessing. Let's see that log.
    chook
    OK, I made the changes to config.txt but did not see anything other than bootid etc. in the Cmdline.txt file. I downloaded the latest nightly. LibreELEC-RPi4.arm-11.0-nightly-20220215-8a018bd.tar and tried an update. It looked OK for a while then kodi rebooted a few times before going into safemode.
    Log is http://ix.io/Removed.
    Chook
    Edited once, last by chook55: privacy (February 16, 2022 at 3:09 AM).
  • chook55
    Feb 16 10:21:03.875429 LibreELEC sh[955]:   File "/storage/.config/argononed.py", line 4, in <module>
    Feb 16 10:21:03.876556 LibreELEC sh[955]:     import smbus
    Feb 16 10:21:03.876556 LibreELEC sh[955]: ModuleNotFoundError: No module named 'smbus'
    Please disable the Argon One demon for testing. The segmentation fault errors don't appear on your latest log.
