I upgraded to LE10 and all seemed fine until a reboot, my AMD A4 x64 PC is locking up on startup with 'BUG: soft lockup - CPU#0 stuck for 22s!' Oddly if I entered the bios and exited with no save it will load up fine.
Details as follows
LibreELEC 10.0.0 (kernel: Linux 5.10.47) Build 19.1.0 Compiled 2021-08-10
GPU: AMD KABINI (DRM 2.5.0, 5.10.47, LLVM 11.0.1)
CPU: AMD A4-5000 APU with Radeon HD Graphics, 798 Mhz
Memory: 8GB
After a bit of googling I discovered a fix for the issue and updated the file /proc/sys/kernel/watchdog_thresh from value 10 to 20, but unfortunately, this did not fix my issue.
Would anyone have any advice? thank you.
