7.0.2.009 build for S905/S905X
  • kszaq: I suppose we can't get the manual for available am_vecm parameters and what they do exactly? One would need to aquire amlogic's SDK?
    I'm afraid there's no manual. :( You have to look at kernel source code and play with the parameters to see the results.
  • I'm afraid there's no manual. :( You have to look at kernel source code and play with the parameters to see the results.
    Thank you...sadly I don't have such knowledge to decypher kernel source code...for many parameters, when I try to change the number inside parameter file from ssh or nano, it saves OK, but it reverts to default number as soon as I play a video...
    Edited once, last by mytbyte ().
  • I see no one seems to have any bluetooth problem, as the only problems I see here seem to be related to audio which works very smoothly on my side.
    Does the BT problem occurs only on the Wetek Hub ?
  • Geremia 24p works fine for me on S905X. Please post link to a sample that causes issues for you.
    Found the issue (which seems to be kodi related?), if i set kodi interface resolution to any interlaced resolution (50i, 60i) then the auto framerate doesn't switch to 24p, instead it choose 60i with 2:3 pulldown
    1. 21:44:50 T:546546381024  NOTICE:  fps: 23.976024, pwidth: 1920, pheight: 1040, dwidth: 1920, dheight: 1040
    2. 21:44:50 T:546546381024   DEBUG: OutputPicture - change configuration. 1920x1040. framerate: 23.98. format: BYPASS
    3. 21:44:50 T:546546381024   DEBUG: Resolution 1920x1080 @ 50.00i - Full Screen (16) not a very good match for fps 23.976 (weight: 0.043), trying 2:3 cadence
    4. 21:44:50 T:546546381024  NOTICE: Display resolution ADJUST : 1920x1080 @ 60.00i - Full Screen (17) (weight: 0.001)
    If kodi interface is set to any progressive resolution, the auto refresh rate finds the correct nearest best resolution 24p
  • I have seen other user reporting issues with BT but nobody posted logs. I will be able to check this today evening.
    I feel a little stupid right now ;p
    Here are some logs : NhYD
    And under LibreELEC > Bluetooth > "No bluetooth adapter found"
  • I do have 2 USB ports, i tried both of them but neither one would boot.
    Hi.
    Same problem here: Bqeel M9C Max s905x 2GB/16GB
    1 SD
    2 USB
    Edited: I even tried build 7.0.2.008, with and without replace device tree.
    Edited once, last by emiliojs ().
  • Did you create the file using a Windows editor, with the Samba share ?
    If so, can you login with a SSH client, and issue a "dos2unix /storage/.config/autostart.sh" ?
    I'm not sure I follow you.
    I created the file on Windows notepad++
    I then copied it to the storage/.Configs folder using a usb.
    I then rebooted.
    Did you execute
    chmod ugo+x ./autostart.sh
    Do I execute this command via ssh?
    Do I have to do this every time I restart?
    MXQ M10 S805 - LibreELEC 8.1.9
    NEXBOX A5 S905X - LibreELEC 8.1.9
    BEELINK MXIII II S905X - LibreELEC 8.1.10
    Edited once, last by kodiuser1 ().
  • Notepad++ is fine, it handles CR/LF fine.
    To run the chmod command (once), you have to login via SSH (root / libreelec).
    2 x Mini M8S II S905X 2 Gb/8 Gb @ LibreELEC 8.2.3.1 running from NAND
  • Okay awesome. Thanks I'll try that when I get home and report back.
  • Fix for non-working BT in WH coming in next build.
    Can anyone interpret this log CJAg and see why my live tv from tvheadend is buffering all the time?
    Can you tell whether you had stuttering in .007 or .008?
    stuttering is on .008 as well, can't get .007 to load as getting can't mount tty job error message. Weird thing is my Nexbox A95X is working great, the problem is only on my new box a droibox ares (rebadged T95X I think)
  • stuttering is on .008 as well, can't get .007 to load as getting can't mount tty job error message. Weird thing is my Nexbox A95X is working great, the problem is only on my new box a droibox ares (rebadged T95X I think)
    Are you using WiFi or Ethernet?
  • Ethernet. Normal videos play perfect including full uncompressed bluray. Playback of recordings are fine, the problem is just livetv
    Edited once, last by ukdaveuk ().
  • For those who love testing new builds I have uploaded one with the following changes:
    Download from: 2016-11-13 2016-11-14
    You have to use device tree from 7.0.2.009 bulid if you update from 7.0.2.008 or older.
  • I experienced a similar problem, because I did not copy the dtb file into the kodi '.update' folder when I loaded the img.gz file. Once I used the dtb file, the problem was corrected. Is it possible the dtb image was not loaded (or maybe an incorrect one??)
    I guess it is possible, but I did put both dtb and img.gz into the update folder. I chose the correct dtb for my box. The audio has been out of sync with .008 and now .009. I think I'll give 7.90 a shot and see how that works out.
    MXIII-G, M8 and Beeklink MXIII Plus LE 8.2.2 - Demetris, Mecool M8S Pro+/Abox A1, Abox A1 Max Coreelec 9.0.2. Thanks to all.
