  • 8.0.1e available to download.
    I have to take at least 10 days break. I won't be updating my builds and won't be writing on forum. Please enjoy the builds responsibly and help each other like you always do. See you later. :angel:
    Thanks for fast fix for Fr and vc-1, I will try it.
    Have a nice time! I send to you a cocktail :)
    Edited once, last by envagyok (April 8, 2017 at 4:49 AM).
  • Thanks for fast fix for Fr and vc-1, I will try it.
    So I tried, everything played at the good frequency, but only a little error.
    when I play after 29.97,59.94 movie 30 or 60 fps, then isn't switch from 59.94 to 60, need to play 24 or 50 fps movie,and then play 30 or 60 fps movie to proper 60Hz sync. (the webui stay 59.94 too after playing 29.97,59.94 movies instead 60Hz need play files or switch fps to 24,or50hz.)
    23.97-24 fps files always setted up correctly.
    Maybe 1/1.001 frame rate switch isn't set back when stop playing 29.97 or 59.94 files and go back to 60fps gui, what remain 59.97fps
    Edited once, last by envagyok (April 8, 2017 at 6:44 AM).
  • then how would I make it a tar file after
    You don't need to. Stick the img.gz file into the update folder, that's all I do.
    Do you realise you are in the wrong part of the forum? this is for S905, you need to be looking at thread-5848.html
    Edited once, last by bubblegum57 (April 8, 2017 at 8:29 AM).
  • Yes, gxbb_p200_2G_1Gbit_OTG_Port.dtb is the correct device tree for the Beelink M18
    Edited once, last by ky41083 (April 8, 2017 at 9:35 AM).
  • Hi, I have problem with playing audio.
    All music with a 44.1kHz bitrate are upsampled to 48kHz (HDMI and SPDIF). I think, this problem is in all 8.x versions. Audio with 96kHz plays correctly as 96khz. But files with 44,1 kHz play as 48 kHz.
    Have you somebody any idea? Advancedsettings, etc... ?
    I have the same problem. The only avalible solution for the moment it using Libreelec Version 7.0.2.009 (based on Jarvis). You'll find more details here:
    thread-1492.html?highlight=44.1
  • Still having RGB Output problems with 8.0.1e, beginning with 8.0.1c or b?
    ~/.config/autostart.sh
    exists with following commands:
    Bash
    #!/bin/sh
    echo 1 > /sys/class/virtual/amhdmitx/amhdmitx0/output_rgb
    The file output_rgb stays empty after reboot or manually starting
    Hylli
    Edited once, last by hylli (April 8, 2017 at 12:47 PM).
  • Is anyone else getting a "no free adapter available" error with TVHeadend on 8.0.1e?
    I have the same NUC, (LibreELEC Version 8.0.1 ) I use Tvhead 4.0 version 8.1.102. I can't get Tvhead 4.2 working, I get communication error message with 4.2
    Just disable tvhead 4.2, then install 4.0 to see if it works.
    I use a USB Tuner plugged into the NUC, so it acts as backend, & client
    My Beelink acts as a client. I haven't updated the Beelink to 8.0.1e yet.
    Perhaps my Tvhead HTSP client needs updating. I'm on version 3.4.19.1 would you know where I can download it?
    To be honest, I don't fully understand Tvhead
