thanks man. yeah. that one doesnt boot for some reason. can you check the attached dtb? thank you so much, man.rk-kernel.dtb.txt
You're sure you tried this LibreELEC-RK322x.arm-9.2-devel-20200427213246-b7186bc-rk3228b-a8.img.gz? If v88mars boots, this should definitly also boot ... I looked at your devicetree ... It matches completly the one I used for createing the v88mars image, Unless you can provide any debugs logs where an/the error appears I can't help
