New release also fixed my problem with video stuttering, thank you!
![](https://forum.libreelec.tv/core/images/avatars/33/121-33e1d470a30cb74bd416ef5a2521611ee621aeb3.png)
Common DVB-T DVB-S dvb-c topic
envagyok -
October 1, 2016 at 6:43 AM -
Updated versions:
LibreELEC-Amlogic.aarch64-KI_Plus-7.0.2.004.4.img.gz
LibreELEC-Amlogic.aarch64-KII_Pro-7.0.2.004.4.img.gz- applied kszaq's fixes: removed hardware demux patch and added a change to allow playing very high bitrate videos.
Thanks for the update.
But there is no easy way to update on NAND installation, right?
I did put updated image on update folder in NAND but it boots to black screen and nothing goes on.I have to fresh install on SD and use ssh to install to NAND. Then restore from backup.
Just notice that the memory leak issue still happen. Have to restart Kodi from time to time.
Wich version of TVHeadend are you guys using. 4.0 or 4.2 Wich one is better ?
Wich version of TVHeadend are you guys using. 4.0 or 4.2 Wich one is better ?4.2
Still beta, but more better and stable as 4.0 -
Still no working DVBT tunner in Ki Plus. No EPG and Power Save on. Anyone knows how to work?
Dvb-t works for me only in Android or libreelec with vdr addon (into kodi). No with tvheadend
Inviato dal mio LG-D802 utilizzando Tapatalk
Dvb-t works for me only in Android or libreelec with vdr addon (into kodi). No with tvheadendInviato dal mio LG-D802 utilizzando Tapatalk
tvheadend is a buggy software, and it don't work with internal tuner DVB-T. But with VDR ALl is working, only problem is that you haven't the LCN
Just curious, does VDR support dvb-t2?
I used to try VDR (on other system) to scan dvb-t2 (in Thailand) but it didn't find any channel at all. But I can always scan all my dvb-t2 TV channel with TVheadend.
I'm in Italy, and I'm unable to use tvheadend for dbv-t. Always scan fail. Vdr scan and find all channels.
William Fanelli
Wich version of TVHeadend are you guys using. 4.0 or 4.2 Wich one is better ?I tried 4.2 last night and didnt see anything obviously wrong with it, worked fine on my M8 mini II
With DVB_T or DVB-S? Anyway, problems is with KI and KII box. TVHeadend with this box, in Italy, fail the scan in DVB-T (but seems work in DVB-S).
If someone have suggestion in order to solve this problemas I will be happy to enable TVHeadend again but I must scan channels, or it is unuseful. -
New version of Tvheadend 4.2 7.0.105 based on revision 2236.
service.tvheadend42-7.0.105.zip- in DVB-S now correctly shows signal level and SNR
- in advance mode is included CA menu -
You can try this:
LibreELEC-Amlogic.aarch64-KI_Plus-7.0.2.003.img.gz
This is alex's latest K1Plus build.
So some thing not work, for example multichannel pcm out..
Please report back. -
I tested with latest 004 my k1plus
The tuner little less sensitivity has, but working both tuner.
I use tvheadend wizard, that find all dvb-s channel, the turn off dvb-s tuner, search dvb-t (generic-auto).
Find all local, but from neighbour country not, so there is sensitivity problem. (other tuners and k1plus with android find it.
Sometimes problem to switch channel (no signal),but later work.
Vdr working good, find more channel, but I don't know enable livetv, then always disable vdr addon, and ask me enable pvr addon. I Enable again, but not work, try restart, then ask again, and vdr plugin disabled. -
You just have to enter configuration for vdr vnsi and save. After that enable the add-on and it will stay enabled.
I have the same problem with Astra 19.2E. Especially none of the UHD/4K channels is found with TvHeadend. With VDR it is not much better expect it finds one UHD/4K channel. But there shoud be about 9 of such channels. I think that it might be a driver issue. The Android DTV app finds all UHD/4K channels on Astra.
Updated versions:
It seams that chapter jump backward triggered from the remote executes a chapter jump forward instead. How could it be corrected? It might belong to a wrong key mapping.
if anyone can see the code and improve drivers?
I have a source of avl6862 -
