Here you go:
Thanks!
Here you go:
Thanks!
LibreELEC-imx6.arm-7.0.0-no.signal.test.img.gz
view?usp=sharing
Please send both logs with this image and mk01 will look them.
Image has kodi running in debug mode, ssh is also enabled by default.
It has some extra Kodi and Linux patches.
Note to myself: pass_events == 0, videoscreen.updateresolutions == true.
vpeter, here are my tests.
on boot, screen was always on and off.
when got screen, was inpossible to go to settings\system(to change resolution)
here is the crash log
gWEC
vpeter, maybe for an idea...is to boot by default to 1980X1080 resolution...just a thought
edit2 i can't work with last "official" version with yatse. i can sync my libraries and reboot.
but buttons are not working, also keyboard doesn't work via yatse. no prob in OE beta...
vpeter, we have a discussion about this problem in a local forum in my country.
someone have mentioned something, that you should consider.
some problems where with TV that don't support FULL HD, or can't downgrade automatcly.
second prob is that LE with kernel 4.4, start with low resolution and low rate.
it will be a good thinking to make a test image, that starts with 1980*1080 with 60 KHZ.
just a thought that wanted to share.
I point logs to mk01. And when he cook something then we can move forward.
Until then it is the situation as is.
Is he reading our suggestions in this forum?
Sent from my SM-E500F using Tapatalk
is it possible to open a specific thread for cubox under cummunity builds thread? think it'll better for all.
Yes, he is reading and aware of the issue. When he cooked something we will know.
Because this issue doesn't happen with my tv I can't help much.
I have same problem, previous version working and the last not working.
Thanks.
Thanks.
Please be aware that it's le7 and not le8 as posted in solid-run forum.
I mean udk's alpha previous version.
I do get screen and it's working here, so can't help with this.
I mean here...
you have to post about alpha in solid run forum.
any news about this vpeter?
